HELP - how to remove the fuel line valve?
Old Sep 19, 2012 | 05:19 AM
Frog's Avatar
Default HELP - how to remove the fuel line valve?
I went over to Dover (UK) yesterday to get my car Terracleaned, but we just couldn't work out how to remove the valve on the fuel line (see photo). We tried every possible combination of pulling, pushing and twisting, but to no avail.
Does anyone know how to get it off?
Incidentally, the guy was very nice and clearly embarrassed I had had a wasted journey. He said he'd done about 50 cars and this was the first time he'd been stumped. Apparently, most cars have an obvious Schrader valve on the fuel line with a blue plastic cap. He did offer to do my engine free of charge once we had sorted the problem out.
Old Sep 19, 2012 | 05:38 AM
I think you are looking for a disconnect tool that slips into the line between the pipe and the fitting.
See this thread https://www.jaguarforums.com/forum/x...l-lines-75920/
Old Sep 19, 2012 | 06:13 AM
avos's Avatar
There is a little spring in there that you need to push out. Have actually just made a tool this weekend. I used a 19mm od plastic pipe, actually from the same pipe where I made the tank fuel line release tool of some time ago ;-), and it has a wall thickness of about 1.3mm. Just cut it open, so you can get it around the fuel line, and push it in the connector, where you should feel a click (or something), then you can wiggle the fuel line out carefully.
Old Sep 19, 2012 | 06:31 AM
Frog's Avatar
Wow, so we needed a special tool... No wonder it wouldn't come off. Thanks, guys
Old Sep 19, 2012 | 07:15 AM
WhiteXKR's Avatar
OK, so figure he does 5 cars a day, that means he has been on the job for 2 weeks. I guess that is believable..these connectors are actually quite common.
dsnyder586
Dec 29, 2024 07:39 PM
Sprayall
May 30, 2021 08:13 AM
Bones
Sep 8, 2015 08:34 PM
AL NZ
Sep 4, 2015 08:39 PM
Sprayall
Sep 3, 2015 07:49 PM
