Help me pick the right part - Dealer is confusing me
Old Apr 25, 2024 | 02:18 PM
scottatl's Avatar
Default Help me pick the right part - Dealer is confusing me
I need to replace my purge control valve. The dealer told me the part I ordered was the wrong version. I can't look at what is installed since i know that one was a replacement part from around 7 years ago, so who knows that may have been the wrong part also even though the code is recent, or maybe both work.
My VIN is SAJGX204XXCO35616, some of the sites cut of the AB at VIN 024686 some cut it off at 042775
This is the email from the dealer,
------Hello Scott
Unfortunately, the VIN provided does not match up with a vehicle in my catalog, thus I am unable to guarantee the part will fit your car. That being said, there is another purge valve LJA1515AA for a SINGLE Emission system.
The LJB1515AB is for a twin emission system, this is defined by having two carbon canisters for the emissions system. If you can let me know which of the two you would like, I will make sure to send the correct part for your car.
Thanks!
Jonathan Estrada
Jaguar Land Rover
This site shows i should be getting the AA https://www.autoreservejaguar.com/xk...lja1515aa.html
This site it looks like i should get the AB, https://parts.jaguarraleigh.com/oem-...alve-lja1515aa
Old Apr 25, 2024 | 02:56 PM
michaelh's Avatar
This Heritage page may help you as you might be able to identify which configuration you have from the diagrams:
https://parts.jaguarlandroverclassic.../brand/jaguar/
JEPC shows 5 different configs, including one for Mexico.
Originally Posted by scottatl
My VIN is ...035616, some of the sites cut of the AB at VIN 024686 some cut it off at 042775
Note that the first short VIN for MY99 is 031303
Sorry I can't give any better help. It is confusing:- I hope mine never fails...
Old Apr 26, 2024 | 11:46 AM
Y2KJag's Avatar
Definitely need to get under the car and confirm which evap system you have. My 2000 has the twin system ORVR, the right-most illustration in @michaelh 's post.
Old Apr 26, 2024 | 04:16 PM
motorcarman's Avatar
I just replaced the front upper damper mounts on a customer car today (1998 XK8) and it is a twin canister car.(I had to remove it for access to the cavity to tilt the damper in there)
I would guess the purge valve itself is the same for all 4.0 X100 but the piping/tubing and connections are different?
You can buy any one you want and just get the plastic hoses to the correct locations to make it work.
The valve itself looks identical to the X308 with different connectors/hoses.(it is basically a Ford part)
Old Apr 26, 2024 | 08:45 PM
scottatl's Avatar
Where do you access the Carbon Canisters so I can see if I have one or two?
Canisters?
Old Apr 27, 2024 | 07:58 AM
I think the location depends on the engine management.
AJ26 seems to be fender and the AJ27 is located near the rear suspension.
Old Apr 28, 2024 | 07:05 PM
Y2KJag's Avatar
Canisters?
On my 2000 XK8 convertible the canisters are attached to the body, behind the rear suspension. There will be one on either side of the car. The purge valve on that end of the car is located on the right side of the car, adjacent to that side's canister. Mine actually have the FoMoCo looo and a a 1995 Ford part number. They look suspiciously like the ones in my Mustang.
The "other" purge valve is located on the left side of the car, under the left front fender liner.
Old Apr 28, 2024 | 08:09 PM
That valve in the back is called the CCV. (CANISTER CLOSE VALVE)
File Type: pdf
Old Apr 28, 2024 | 08:15 PM
Y2KJag's Avatar
Thanks!!
stmcknig
Nov 12, 2025 12:27 PM
stojan.jovic
XE ( X760 )
May 26, 2021 06:54 AM
Frenchy
May 29, 2015 04:29 PM
azad
Dec 30, 2010 02:07 PM
newuser
Apr 6, 2010 08:29 PM
