High pressure power steering hose replacement
Old Jun 16, 2014 | 06:59 PM
noterman's Avatar
Default High pressure power steering hose replacement
I have a leak in my power steering hose from the pump to the steering rack. Any hints on how to replace the hose and a good place to buy a replacement.
Old Jun 19, 2014 | 08:35 AM
weisberg's Avatar
Gaudin Jaguar in NV sells parts at aggressive prices. Just triple check parts you order and need
Old Jun 19, 2014 | 10:13 AM
TreVoRTasmin's Avatar
A hydraulic shop should be able to make you one for $30 or so. Just take your old one in and they'll reuse the fittings.
Old Jun 20, 2014 | 05:34 AM
East Haddam's Avatar
That is a money saver as Jag really charges a chunk of change for the hose. If it's as tough to replace as the one I replaced in my old V12 XKS you might learn a few new swear words. Anyone done one of these replacements recently?
RB
Old Jun 20, 2014 | 07:48 AM
aode06's Avatar
noterman your signature is empty, please fix that so we know what kinda of vehicle we are dealing with here
Old Jul 3, 2015 | 07:12 PM
Ratchetbinder's Avatar
You, are awesome!!! I'm kicking myself for not thinking of that since I've worked with hydraulic hoses in the past lmbo ..thanks! Probably saved me a bundle as it appears my wife's xk8 just blew a power steering supply hose..hoping it's not engine oil but looked like power steering fluid from high pressure line and happened all of a sudden while parallel parking and lots of smoke from hitting exhaust...have to get it off the ground to know for sure because the wife is a good cook and overfeeds me on occasion
Old Dec 16, 2015 | 12:23 PM
stevepaa's Avatar
just happened to me with white cloud
jacked up car on stands and it is the hi pressure hose where the rubber hose meets the end fitting
when i wiggled the hose I could see fluid moving
Attached Thumbnails High pressure power steering hose replacement-img_4494.jpg   High pressure power steering hose replacement-img_4498.jpg
Old Jan 30, 2016 | 04:31 PM
hugh ness's Avatar
guys, i am having a leak as well. s3 xj6
power steering leaks from the fitting off the rack in the line. seeping through the thread. do these lines have an o ring in there to stop leaking? Just pulled mine out but no o ring. Or is is an indication I need new lines? Thanks
Peter
fast40driver
Apr 19, 2024 07:24 AM
rusty37
Jun 7, 2016 04:43 PM
NTL1991
XJ40 ( XJ81 )
Sep 24, 2015 09:09 PM
big d
Sep 3, 2015 07:37 PM
johanasu
Sep 3, 2015 12:39 PM
