High revs on cold start.
Another issue has raised it's head. When the car is started from cold the revs are higher than normal(too high) and take a while to settle down, once it has settled it can be started and all is well. Any thoughts on this latest issue are much appreciated. Many thanks again. Anthony. Happy new year to you all.
Superchargedxkr (02-08-2023)
My XK8 starts with an idle speed of about 1.400 rpm, no matter if the ambient temperature is 0 or 30 degrees C. It takes about a minute for the revs to slowly drop to 700 -800 rpm. I usually wait with the gear lever putting into Drive until the revs have reduced a little.
Curious to know whether your jags also behave like this? I do not know the high cold start speed of other vehicles so.
Fritz
Fritz
The following 3 users liked this post by flatsix:
Fritz
Fritz
Only reason why I let the revs drop before moving off is because the car makes a lot of power at 1500rpm or so which can catch you out if you don't expect it. I always have to tell people to let the revs drop first and keep you're foot on the brake. A few times people have almost rammed into another car because they thought it would just creep forward like it tends to do at normal idle.
The following 2 users liked this post by Kuddlesworth:
Markmbaha1 (02-10-2023),
zray (12-30-2022)
https://www.jaguarforums.com/forum/x...d-cold-214016/
Have you checked what throttle percentage is shown without your foot on the gas using Torque etc? Maybe you can adjust it down.
zray (12-30-2022)
Looking at the thread has(i think) solved the problem, which is related to me having to disconnect the battery every night due to the problem i have with the micro switch on the drivers window. When the window issue is resolved and i no longer need to remove the battery hopefully things will return to normal. Many thanks.
Received 1,605 Likes
is your car parked where you can just leave the window down when parked nighttime ? That way you can leave the battery hooked up and avoid the learning procedure with the attendant high rpm upon starting every day.
Z
