Houston, we have a problem! Please help.
Old Apr 24, 2011 | 05:30 PM
Mish_Mish's Avatar
Default Houston, we have a problem! Please help.
After all the talk about leaky convertible line, I went ahead and made things even worse!
1. There was a slow green oil leak, over driver's feet at my XKR. I was told that this is due to some line splicing, supposedly done by some dealer..
2. True, there were two compression fitted quick connects, one on each line, in the area of left pillar. This is where oil was slowly leaking down the lines, over some electric cables and onto my feet.
3. I decided to redo compression fittings, where plastic line screws onto them and accidentally snapped one of the screws that goes into the plastic lines.
At this point I have option to try and find new fitting, or possibly replace the whole line perhaps?
The upper line, where the fitting was connected looks perfect and new, however the lower lines that go all the way to the pump look old and oily, with black outer insulation peeling off.
Please suggest what do to and where to get parts!!! Thanks again, as always!
Old Apr 24, 2011 | 07:33 PM
2002XK8Orlando's Avatar
Replace both lines entirely....you can use Gus for the updated stronger hoses or the dealer network for the OEM hoses
Old Apr 24, 2011 | 08:08 PM
Mish_Mish's Avatar
So I assume that solid hose replacement is the safer way to go. Especially since old part of the hoses is a bit rotten looking, with black outer wrapping peeling off in chunks.
What is the difference between:
HJB-8256-AA - $225 at Welshent.com
and
HJB-8256-AB - $221 from few places.
Old Apr 24, 2011 | 08:20 PM
AB is the new improved (?) hose. AA is the original hose.
Old Apr 24, 2011 | 08:40 PM
stevepaa's Avatar
$208 from
Direct JPLV Porsche Parts.com
Old Apr 24, 2011 | 11:54 PM
Nce Kty's Avatar
+1 on checking Gus Glikas's pages here on the forum. Most valuable to you right now are:
I have installed the pressure relief valve. I highly recommend doing so even after installing the new hoses that Gus had manufactured to his exacting specifications (meaning over-engineered so that they will last a lifetime).
Following Gus's advice will give you peace of mind knowing that it will indeed be a one-time fix and well worth the investment in parts and time.
Good luck and let us know how it works out for you!
Old Apr 25, 2011 | 01:40 AM
plums's Avatar
Originally Posted by jhndavid
Information on JAGUAR XK8 CONVERTIBLE,
... spam flavoured wedding cakes
Old Apr 25, 2011 | 08:01 AM
Mish_Mish's Avatar
Could somone sell me their old quick conect fitting, for the time being?
I will order new hoses today, but not sure how soon I can get to do the job. For now it would be nice to be able to drive the car, due to nice weather and my wife stopping to criticise my mad mechanic's skills would also be nice...
Old Apr 25, 2011 | 02:43 PM
Mish_Mish's Avatar
Just purchased HJB8256AB at a local dealership, $217!
Old Apr 26, 2011 | 10:55 PM
elkriver's Avatar
Is it just one hose or a set of two? Is it a solid piece of plastic tubing or does it have reinforcement and a jacket?
I need to replace the Nylaflows on our 99. Trying to decide how I want to proceed.
Old Apr 27, 2011 | 06:22 AM
Mish_Mish's Avatar
It is a set of two, black hoses. These are plastic tubing, with reinforcement jacket and black outer casing.
AB version is the updated, higher pressure rated version from dealer.
Old Apr 27, 2011 | 08:31 AM
Brutal's Avatar
And this is exactly why jaguar doing the splice. Cause the hose is deteriorated and the black outsheild coming off leading to leaks at the splice. Its always better to replace the whole thing. We did a couple and do to this problem we never did naymore even before jaguar pulled the plug. We also will not do splices when we have customers come in and ask or request it. All thos hoses are now even older and way out of warranty and if it wasnt a good repair under warranty it sure as hell aint gonna work well now
Old Apr 27, 2011 | 10:31 AM
Mish_Mish's Avatar
Mine had electric tape around the cut hose, so it fits tighter inside the fitting, how crappy is that!?
Also, as I uncovered the rest of the hose, it was already sweating oil through, in multiple places, along the way to the pump.
BTW, this job is not hard at all, if I was not fixing 5 other things on the way (ashtray, broken plastic brackets, steering column motor, rusty hole in the floor, replacing J-gate, welding cracked lower seat frame...), I'd be done in 3-4 hours, while watching kids go crazy in the yard.
Attached Thumbnails Houston, we have a problem! Please help.-p1030897.jpg   Houston, we have a problem! Please help.-p1030899.jpg   Houston, we have a problem! Please help.-p1030900.jpg   Houston, we have a problem! Please help.-p1030902.jpg   Houston, we have a problem! Please help.-p1030907.jpg
Old Apr 27, 2011 | 08:59 PM
Mish_Mish's Avatar
Maybe I spoke too soon about 3-4 hours. This job is very annoying and tidious. I am all the way back, at the right rear corner and it is too dark in garage to continue. My eyes are not what they used to be, no more cat vision for me
I did fix hole in the floor and broken seat frame, from previous owner's fat can! I loved welding that seat frame, it went like butter
Attached Thumbnails Houston, we have a problem! Please help.-88cdd3255b458cf3-large.jpg   Houston, we have a problem! Please help.-88cdd32590969f56-large.jpg   Houston, we have a problem! Please help.-88cdd32542614936-large.jpg   Houston, we have a problem! Please help.-88cdd32538e7aefe-large.jpg
Old May 1, 2011 | 09:16 PM
Mish_Mish's Avatar
I am finally done with hydraulics and reassembling the interior. All I have left to put back is armrest.
OMG, to get it done properly (with all zipties and other minor tidying up) took me about 8 hours, plus another ~7 to fix 5-6 other issues I ran into.
Old lines were ready to blow in few placees, I found at least 3 areas where these were already sweating oil through.
Another fun thing I did, was reupholstering front roof liner. Fabric there was getting ready to sag down. 3M upholstery spray glue did wonders.
Thank you for all the advise, it would have been a lot harder without your guidance, especially Gus!
Old May 1, 2011 | 09:53 PM
Brutal's Avatar
The factory uses duct tape, useally black I use whats in stock, black or gray..
Its used in a few areas, especially around corners to protect from abrasion and hold in place, I meen there is a reason its called 200mph tape!!!!!
Old May 2, 2011 | 09:20 AM
Mish_Mish's Avatar
The reason why they used electric tape under screw-in compression fitting, was because original black outer jacket already rotted off the factory hoses. So to make fitting snug, they wrapped tape around, instead of replacing the entire hoses, like they should have.
In any case, it is now all in the past and when voltage reduction kit from Reverend comes in, I will be able to drop and close my roof, even with the motor running and without turning blower fan all the way up
Old May 2, 2011 | 12:40 PM
H20boy's Avatar
the broken seat was humorous, but good job on completing the project mish x2!
way2far
Aug 31, 2022 09:26 AM
JakeXKE
E type ( XK-E )
Jul 6, 2021 06:49 PM
nitrolouie2142
Sep 5, 2015 01:55 PM
edtexas
Sep 5, 2015 10:49 AM
laserguy
Sep 3, 2015 02:02 PM
