How to add xk8 convertible top hydraulic fluid
The tank is located to the right of the trunk just above the CD player you will need to remove the panel covering it. The pump and tank are attached and the fill is a plug at the top of the tank. It can be filled without removing it from the rack but you will need a syringe with a tube to fill it JagRepair.com - Jaguar Repair Information Resource
The following 2 users liked this post by Gus:
Bull_gator (01-05-2021),
Orthodixie (03-25-2017)
99xk8guy
06-05-2023 06:28 AM
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
11-23-2015 01:56 PM
