how is antifreeze ending up here?
Old May 22, 2024 | 07:53 PM
scottatl's Avatar
Default how is antifreeze ending up here?
It is the same on both sides, down by the knock sensors.
Old May 22, 2024 | 08:13 PM
if you are not seeing anywhere else along the top of the engine, then most likely the valley hoses
Old May 22, 2024 | 08:31 PM
scottatl's Avatar
i did overheat so i wonder if it is the head gasket. I am not sure if i have it in me to replace those gaskets.
Old May 23, 2024 | 05:50 AM
RJ237's Avatar
Head gaskets would not leak in that area, they are much lower.
Old May 23, 2024 | 07:54 AM
JimmyL's Avatar
Could be the Norma connectors on the ends of the octopus hose. They all start to drip eventually.
Old May 23, 2024 | 08:51 AM
RJ237's Avatar
Norma connectors are lower than the knock sensors. Only the valley hose or thermostat housing could leave a puddle around the sensor.
Old May 23, 2024 | 03:23 PM
scottatl's Avatar
thanks everyone
monacoftype16
Jan 16, 2024 09:02 AM
Amira Lauderdale
Jun 15, 2021 05:04 PM
Syb Drylst
Jun 6, 2020 12:42 AM
Javier Mena
Europe
Feb 23, 2014 02:44 PM
XF - Xtra Fast
Oct 31, 2012 04:48 AM
