How do I remove fix the hose that pulled out of my 2003 jaguar xk8 convertible pump?
Old Jun 2, 2018 | 11:25 PM
datary56's Avatar
Default How do I remove fix the hose that pulled out of my 2003 jaguar xk8 convertible pump?
Old Jun 3, 2018 | 08:45 AM
cjd777's Avatar
If that one pulled out the others are not far behind.
Bit the bullet and get new ones all around and you will be a much happier camper.
Big job but lots of write ups on the how too do section.
Gus's is great and mine for the ram hoses gives all info down to the size wrench or socket. You will need lots of places to put things that come off so you can keep it organized.
Old Jun 3, 2018 | 09:18 AM
I used Cabriolet Hydraulics for my replacement hoses but Topsonline also sells replacement hoses - both much better quality and pressure ratings than the OEM hoses. Topsonline also offers rebuild services for the rams and top latch mechanism so if there are any leaking seals - they would be the route to take
Old Jun 3, 2018 | 05:02 PM
frankc's Avatar
If you mean you have a leaking hose or you wish to replace one this may help a little :-
https://www.jaguarforum.com/showthre...=1#post1094300
Hope it helps
Mad Mikey
Jan 22, 2019 09:06 AM
resident_fng
May 23, 2018 06:18 AM
Anglicomarine0326
May 17, 2018 09:46 PM
Biff Baxter
Apr 30, 2018 09:51 PM
Kevin Drain
Apr 18, 2018 08:50 AM
