How Do You Remove the fuel line connection?
Old Mar 8, 2017 | 07:10 PM
daro31's Avatar
Default How Do You Remove the fuel line connection?
There seems to be some sort of anew internal something that pulls back when you try and pull off the fuel line hose to the fuel rail. Anyone know how this comes apart. I got the intake manifold off to replace the valley hoses, but had to leave the manifold just set to the side duets this connection. How does this come apart?
Old Mar 8, 2017 | 08:02 PM
Om28v's Avatar
Someone will get an answer for you soon. Don't force it, I gotta think that's a pretty high pressure hose.
This surgery is in my future, please take lots of pictures.
Beautiful car. Closest one I've seen to mine...maybe exactly the same. Mines an 05 and the blue may be a touch different...or not.
Old Mar 8, 2017 | 08:08 PM
daro31's Avatar
My car is an 04, the colour is Pacific Blue.
Om28v's Avatar
Old Mar 8, 2017 | 08:11 PM
Om28v's Avatar
Mines I dunno color, beautiful though. That connection is driving me bonkers on your car.
Some one chime in. Put vice grips down!
Old Mar 8, 2017 | 08:18 PM
Om28v's Avatar
Pacific blue/ ivory?
Old Mar 8, 2017 | 08:51 PM
motorcarman's Avatar
It's a 'FORD-THING'. A fairly common method of A/C and Fuel Line disconnection tools are required.
Old Mar 8, 2017 | 09:15 PM
Om28v's Avatar
Ha. There it is. I still don't get it.
Old Mar 8, 2017 | 09:27 PM
Paul Pavlik's Avatar
The sleeve on the correct size tool presses into the metal fitting permitting separation.
Old Mar 9, 2017 | 02:22 AM
DevonDavid's Avatar
Not as shiny as yours (!!) - this was a scrap one I got for free just to investigate.
The "female" part has four internal lugs which trap the raised ridge on the "male" pipe.
so with the correct tool - either one of the plastic ones or one like mine, you slide the tool in to compress the lugs, then pull the whole "male" assembly out.
I think that's the same as yours. Mine is off an early XK8 so there may be minor differences ?
Old Mar 9, 2017 | 10:08 AM
daro31's Avatar
I had the right tools, I was just going at the wrong part of the fitting. Thanks for the help
Old Mar 9, 2017 | 02:11 PM
DevonDavid's Avatar
I must admit that when I saw where your arrow was pointing, I had my suspicions, but was too polite to ask :-)
I envy your shiny pipes - is that just wire-wool and hard work, or is there a secret formula ?
Old Mar 9, 2017 | 02:51 PM
daro31's Avatar
Just the way the pipes are, no elbow grease at all in them.
