How important? Putting sprockets back on
Old Jul 29, 2018 | 12:58 AM
IXLLER8's Avatar
Default How important? Putting sprockets back on
Hi
I am going to put my chains and tensioners back on and stumble over this information in the instructions available here in the Forums:
”The sprockets must be kept in the same orientation, or upon indtallation male sure that the sprocekts are 1/2 tooth out og phase”
Well, I kept the orientation right, but why is it important that sprocekts are 1/2 tooth out of phase - I believe the chain will determine that? Or what am I missing?
Old Jul 29, 2018 | 02:57 AM
DevonDavid's Avatar
Others with more expertise may arrive to help, but I think what you are looking at refers to the two **crankshaft** sprockets. These are identical and both have a keyway for correct location. However, when they are installed, the teeth will be half-a-tooth out off phase with each other as they locate on the crankshaft.
Old Jul 29, 2018 | 03:02 AM
dibbit's Avatar
Because the correct distance apart isn't a whole number of chain links, it needs the extra 1/2 a chain link to get the correct distance, so that the two shafts are aligned correctly and not slightly out of sync.
Old Jul 29, 2018 | 03:03 AM
IXLLER8's Avatar
Got it:-)
Old Jul 29, 2018 | 04:39 AM
michaelh's Avatar
Default Likely a dumb question
...but, given that the alignment between the cam sprockets and the cams is infinitely variable, why does it matter?
Old Jul 29, 2018 | 05:12 AM
IXLLER8's Avatar
That also confused me..;-)...but problem solved - I am proceeding with assembly;-)
Old Jul 29, 2018 | 08:15 AM
motorcarman's Avatar
Probably has to do with the pivot pins in the links not touching each other at the crank sprockets or maybe harmonics in the chains?
Just do it and go on with the rest of the job. (because Jaguar says so!!)
bob
Old Jul 29, 2018 | 04:16 PM
michaelh's Avatar
Thanks, Bob.
That's the only reason I could think of as it allows the links to interleave - but it only allows the sprockets to be what - 2mm closer together?
As you say, JFDI 'coz Jaguar says so, and they must have an engineering reason. Just curious.
Old Aug 2, 2018 | 08:33 AM
darbysan's Avatar
I've seen this before on double roller chains on Front Wheel Drive transmissions. The links there were out of phase by 1/2 tooth, just like above, to reduce chain noise. Guess the harmonics phasing helps cancel out the noise.
Clouder
Jun 28, 2020 02:19 PM
rgp
Nov 1, 2017 08:16 AM
euphonium01
Jul 9, 2016 05:25 PM
