How many miles (or km) on your 1998-2003 XK8 ?
Subscribe
Jan 19, 2016 | 10:52 AM
I see a lot of fairly low miles referenced on most of the XK8's and Jaguars in general. I belong to a couple of other auto forums, and some like Chevy S10 pick ups from the 1990's are approaching 400,000 miles (granted only a few) on original engines. Conversely a lot of very low mileage Corvettes (especially Z06). I assume this is because the Corvettes and Jaguars are for the most part not daily drivers. So is anyone that has the Jag as their daily driver up near 200,000 miles or even more? It would be interesting to know what has been replaced by that time for you high mileage folks. Especially if properly maintained are the engines still good ? Certainly at ~300 motor hp it should not be unduly stressed.
My 2000 XK8 = 95,000 miles
Reply 0
Jan 19, 2016 | 10:56 AM
103k and running strong!
Reply 0
Jan 19, 2016 | 11:12 AM
Mine is a '97 and it has 100743 on it now. Owned it almost 2 years.
Repaired ECU at ASI
Replaced plugs, coils
Replaced water pump, T-stat, t-stat housing, radiator hoses, bypass hose, coolant, ECU temp sensor.
Replaced emergency brake cable
Gas filter
Brake/CC switches
Repaired stereo power amp.
Tires
Cleaned MAS/Throttle body
New air filter and filter box rubber mount.
Tensioner and idler pulleys and belt.
Still to do:
Check secondary tensioners and replace if not already done
Repair ABS module.
Dave
Reply 0
Jan 19, 2016 | 11:36 AM
I've seen a couple of owners here mention that they have 160,000 to 170,000 miles on their XK8/XKR. I believe that both of them are pre-2000 models. One is a SoCal car and I can't remember where the other one lives. Maybe they'll see this thread and chime in for you....
My wife's daily-driver 2006 XK8 is still running strong at 99,500 miles. No engine work required on her 4.2 yet but I've replaced some of the cooling system's plastic ductwork (which is typical)....
Count me in the group that believes these cars stay healthier when they are driven regularly....
Reply 0
Jan 19, 2016 | 11:37 AM
123,000 and owned 1 yr. General maintenance items plus plastic cooling tower and water pump. Transmission filter & fluid changed along with added rear dif. drain plug and lube renewal. Appears ready for another 100K, (I may not be around to finish it :-)
Reply 0
Jan 19, 2016 | 12:15 PM
Just turned 80k miles here. Cooling system just overhauled with new radiator, water pump and thermostat. New Alternator also fitted. New tires, discs, pads. MOT and service. Nothing spent for the first 3 years ownership, then bang over £3k - easy come easy go hey!
Reply 0
Jan 19, 2016 | 12:50 PM
117,758 on my XK8. Lost the a-drum at 97,000 miles no other heavy maintenance issues.
Reply 0
Jan 19, 2016 | 01:00 PM
Quote: Just turned 80k miles here. Cooling system just overhauled with new radiator, water pump and thermostat. New Alternator also fitted. New tires, discs, pads. MOT and service. Nothing spent for the first 3 years ownership, then bang over £3k - easy come easy go hey!
Didn't do any of the radiator hoses that are many on these cars?
Reply 0
Jan 19, 2016 | 01:37 PM
Quote: Didn't do any of the radiator hoses that are many on these cars?
Well, I didn't do it myself. But the indy I use would've checked the hoses I'd imagine. He had the car long enough. When I speak to him again I will ask the question. Otherwise the care seems to be going perfect.
Reply 0
Jan 19, 2016 | 01:58 PM
My 4 year anniversary with my 2000 XK8 will be Feb 12 - she is my daily driver and I am at 149650 (purchased with 91K on clock).
All cooling hoses have been replaced within the last 8 months
Radiator replaced last week due to crack in plastic tank
Tranny rebuilt at 130K
rear wheel bearing, hub carrier & rotor
plugs/coils
part load and full load breathers
air intake tube
fuel filter
front suspension
evap canister
new rims/tires
next for action - rear suspension, cam cover gaskets/vvt seal/boss&spark plug seals
Reply 0
Jan 19, 2016 | 02:01 PM
I live in Florida and my '99 has 167k on it. I have owned the car for 5 years and will keep it till dead then restore it. I have had major issues with transmission (one rebuild and one replacement) and replace head gasket (did value job while off). Have to redo front end thump now and chase down fuel smell.
This is a 17 yr old car and I get compliments on it every day. You can check out my post on maintenance cost I posted earlier this month. It was costly last year but still cheaper than an car payment. When is the last time you looked at a guy driving an SUV or truck and thought, "what a nice ride".
Reply 0
Jan 19, 2016 | 03:45 PM
Quote: Well, I didn't do it myself. But the indy I use would've checked the hoses I'd imagine. He had the car long enough. When I speak to him again I will ask the question. Otherwise the care seems to be going perfect.
You would have seen it in the BILL if he did them all. Rad hoses, valley hoses, octopus hose, and hand full of smaller ones.
Reply 0
Jan 19, 2016 | 04:31 PM
My '01 blue cat has 137k miles with 4 years on my watch. Bought it with ~90k miles on the clock.
Changed radiator and hoses, expansion tank, front shocks and coils, fuel pump, starter and alternator.
Reply 0
Jan 19, 2016 | 06:39 PM
2001 XK8
Quote: I see a lot of fairly low miles referenced on most of the XK8's and Jaguars in general. I belong to a couple of other auto forums, and some like Chevy S10 pick ups from the 1990's are approaching 400,000 miles (granted only a few) on original engines. Conversely a lot of very low mileage Corvettes (especially Z06). I assume this is because the Corvettes and Jaguars are for the most part not daily drivers. So is anyone that has the Jag as their daily driver up near 200,000 miles or even more? It would be interesting to know what has been replaced by that time for you high mileage folks. Especially if properly maintained are the engines still good ? Certainly at ~300 motor hp it should not be unduly stressed.
My 2001 has about 61,500 miles on it. I have replaced wheel bearings, water pump and washer fluid reservoir. I need a passenger seat control unit and my fuel gauge doesn't work. Other than that, car looks and runs great!
Reply 0
Jan 19, 2016 | 08:06 PM
My daily driver and cross-country steed is an '03 XKR with 183,000 miles on it. I bought her 3 1/2 years ago with 101K on the clock. The engine "was" making an odd ticking sound and, sure enough, 30K miles later I needed another one. The engine in the car now has 100K miles on it. In addition to the engine, I've changed the following:
Water Pump
Serpentine belts and pulleys ( a little squeaking had started)
Coolant Thermostat (she was taking time to warm and twice did not warm completely)
Some hoses (preventative only - no failures)
One front wheel bearing
One rear wheel hub assembly (replacing botched dealership repair!)
All four O2 Sensors (might not actually have been necessary)
Tranny filter and fluid (MERCON - works great!)
S/C Oil (actually made it quieter)
One Oil Cooler Hose (another one still weeps a little)
Coolant Reservoir (and the new one has the same tiny leak! - groan)
Front Upper Suspension Bushings (Holy smoke - they were shot. Replace yours NOW!!!)
She'll soon get a replacement steering column (tilt and telescope failed, of course), some new light bulbs in the dash and center console, and a repair to the driver's door card mounting points (opened and closed a "few" too many times - lol)
And there's a slight vacuum leak somewhere that throws a P0171 code now and then. I'll track it down, .... "someday". ;-)
She has driven through rain and snow and has taken a huge chunk of truck tread right to her snout at highway speed. Yet she still polishes up beautifully and the interior is pristine. Truly, the only indication of her age is the sand blasted windshield from all the highway miles (which I hope to replace next year). She absolutely loves to effortlessly cruise at 90 mph - lol. What a gal.
DRIVE YOUR FRIGGIN' CARS!!!
Reply 0
Jan 19, 2016 | 08:49 PM
mine is a 97 {prod date 9-96 #825} i gess i am lo at 102,600. had it almost 1yr .so far ecm rebuild , tune up servise .and it looks like i need a heat ac panel .over all perty good luck out of a 19yr old ride.
Reply 0
Jan 19, 2016 | 09:12 PM
I just bought a 2000 Coupe that just hit 73,000miles/117,500km. Thats what the clock says and the bill of sale but the carfax says 129,000 miles so I'm kind of at a loss what the actual mileage is?
Reply 0
Jan 19, 2016 | 09:21 PM
Quote: I just bought a 2000 Coupe that just hit 73,000miles/117,500km. Thats what the clock says and the bill of sale but the carfax says 129,000 miles so I'm kind of at a loss what the actual mileage is?
Is there more than one entry on CARFAX that is consistent with the 129,000 miles ? Typos do happen (both on mileage entries and also when VIN is entered on a service record). Odd thing with mine is that all service records through 2007 show up on CARFAX, but after that only the smog checks show. Fortunately I have the original service records from the local Jag dealer after 2007, but as I said none of those are listed by CARFAX. Also in CA once a car is 10 years old mileage does not have to be reported on sale and no mileage statement is required. Again though, the smog check record will show mileage accurately every 2 years.
Reply 0
Jan 19, 2016 | 09:50 PM
Quote: Is there more than one entry on CARFAX that is consistent with the 129,000 miles ? Typos do happen (both on mileage entries and also when VIN is entered on a service record). Odd thing with mine is that all service records through 2007 show up on CARFAX, but after that only the smog checks show. Fortunately I have the original service records from the local Jag dealer after 2007, but as I said none of those are listed by CARFAX. Also in CA once a car is 10 years old mileage does not have to be reported on sale and no mileage statement is required. Again though, the smog check record will show mileage accurately every 2 years.
Well here is the most recent on the car fax, it goes to the middle of 2014
Reply 0
Jan 19, 2016 | 10:14 PM
I may be the SoCal car Jon89 was referring to as I have approximately 160,000 miles on my 2002 XKR. It looks nearly new, runs as well or better than it did when I got it (60,000 miles) 6 years ago. I alternate between my 2010 XKR coupe and my 2002 XKR convertible. Love 'em both for different reasons.
Reply 0
