How much shim to adjust rear camber?
Old May 5, 2011 | 10:00 AM
pauljoane's Avatar
2001 vanden Plau with 54K miles. Forgot to mention the left front upper control arm is bent to the tune of 1000 dollors. Would any of you reccomend a used control arm eith new bushings and ball joint?
Old May 5, 2011 | 10:34 AM
Brutal's Avatar
Absolutly
Old May 5, 2011 | 08:48 PM
pauljoane's Avatar
Brutal, does your response, absolutely, the answer to my question on shimes at 10:54 and my question on used upper control arm at 11:00? Just want to be clear. Paul
Old May 8, 2011 | 10:46 AM
H20boy's Avatar
check with Gaudin Jaguar and our other sponsor Nalley Jaguar, I bought new front, lower control arms for $250 each, with new bushings.
Just checked Gaudin Jaguar's interactive website, and upper a-arm is only $250 each, and yes, comes with the bushings and ball joint in it.
Old May 9, 2011 | 05:24 AM
pauljoane's Avatar
Thank you for the input on Goudin Jaguar, I will look into it. I have been getting advice not to do anything about the upper control arm since the camber is only out -0.67 and the old tires I took off were not wearing unevenly. The car does drift slightly right when you take your hands off the wheel. Would packing that spring help? Any input would help.
GordoCatCar
Jan 2, 2017 01:10 PM
ym37tech
Feb 8, 2016 01:04 PM
1LowCat
Sep 14, 2015 07:51 PM
Richard_gib
Sep 12, 2015 07:08 PM
aktell
Sep 10, 2015 02:55 PM
