How to release the ram piston from the mount?
Old Mar 31, 2012 | 10:27 AM
moonpetal38's Avatar
Default How to release the ram piston from the mount?
Hello!! Hubby is outside ready to replace the ram pistons on both sides of my xk. He has got it all torn apart but can't figure out how to release the piston from the mount. Please help. Thanks.
Old Mar 31, 2012 | 10:41 AM
Try this.
File Type: pdf
Old Mar 31, 2012 | 10:55 AM
Originally Posted by Norri
Try this.
Thank you so much!!
Old Mar 31, 2012 | 11:42 AM
Another question....will there be excess air? Do we need to bleed it somehow? Thanks.
Old Mar 31, 2012 | 11:50 AM
WhiteXKR's Avatar
The system is self bleeding. It may cycle slowly the first few times until all the air gets out though.
Old Mar 31, 2012 | 12:07 PM
I found the answer about bleeding the hydraulics. But now another problem. All was installed and we went to crank the car to raise the raise. The car won't start. All we get is a click. It cranked earlier today before he started. All we did was changed the two rams. Any ideas on what happened? Thanks again.
Old Mar 31, 2012 | 12:09 PM
I found the answer before seeing your response. Thank you though. I am hoping you are still hanging around to help with the newest problem. I love this car but my goodness....it is ornery.
Old Mar 31, 2012 | 12:13 PM
WhiteXKR's Avatar
Any chance the battery is low...perhaps the doors left open overnight while in the midst of the work?
Old Mar 31, 2012 | 12:20 PM
He cranked it just an hour before. He is just now going out to jump it. Something had to really drain that battery fast for it to happen like that. Stranger things have happened i guess. I will let you know in a few minutes. Poor hubby....he really wanted to work on his baby today, not mine.
That did it. It cranked up. Wonder why the battery went dead so fast. Thanks for your fast reply and help. (As always).
Old Mar 31, 2012 | 12:23 PM
WhiteXKR's Avatar
It does not take much if a battery is on its way out.
Finbarr1975
Sep 5, 2025 08:38 PM
MrWhite
33
Oct 22, 2015 10:29 AM
adam699
Oct 13, 2015 05:53 PM
Lawrence
XJ40 ( XJ81 )
Oct 1, 2015 08:36 AM
