How to secure a ball joint to put nut back on?
Old Jul 19, 2025 | 04:22 PM
scottatl's Avatar
Default How to secure a ball joint to put nut back on?
The bolt spins so I cant secure the nut. It seems to have a small indentation in the bolt that you would think would be an allen wrench slot, but it is just a smooth round indentation.
fist, is the ball joint supposed to spin? i am assuming it should, or maybe the ball joint is broken.
if it is supposed to spin, how do you secure the bolt?
Old Jul 19, 2025 | 04:57 PM
rothwell's Avatar
My guess would be you need an impact tool to get enough speed/torque that will pull it all together and get some friction on the top mating surface of the joint to prevent further rotation. From there it should be able to be torqued to spec. Odd those don't have the allen key slot.
Old Jul 19, 2025 | 05:21 PM
motorcarman's Avatar
You can PRY DOWN (or up) on the control arm to engage the taper for extra friction.
Old Jul 19, 2025 | 07:21 PM
watto700's Avatar
G'day Scott,
One suggestion is to get a nut without the nylock insert and screw the balljoint into place then finish the job with the nylock nut.
Cheers,
Jeff.
Old Jul 19, 2025 | 08:18 PM
scottatl's Avatar
All interesting ideas, i will give them a go. i may use of combination of a non locking nut and prying down on the arm.
Old Jul 20, 2025 | 01:48 AM
Pistnbroke's Avatar
If the ball is facing down put a jack under it if its upwards you will have to press it down with crowbar etc or a clamp
Old Jul 20, 2025 | 03:45 AM
XK8 SR UK's Avatar
If you have one, a g-clamp can also help put enough pressure on the ball joint for the friction surface to catch and allow you to tighten. I used this on my wishbones recently, allows you to set the pressure and manoeuvre yourself where you need to be.
David Dougherty
Apr 19, 2024 04:20 AM
worzella
Jun 27, 2021 06:47 PM
PartsProjects
16
Mar 22, 2021 08:13 AM
d a
Jun 20, 2020 11:03 AM
axr6
May 7, 2014 12:57 PM
