hydraulic ram issue
Old Jul 12, 2016 | 10:39 AM
dr.fixit's Avatar
Default hydraulic ram issue
Just discovered my right hand hydro ram has broken loose from its mount. Can't figure out how it should be. Does anyone have a pic of it mounted?? Also the limit switch connections snapped off. The small brass screws will need to be replaced. Any idea as to the size and thread? Any help is appreciated.
Old Jul 12, 2016 | 12:07 PM
dsnyder586's Avatar
Hey Dr. I have a 98 XK8 I can take pictures from (parting out) can you PM me a picture (or post here) of what is broken and I can take a pic of mine?
Old Jul 12, 2016 | 02:32 PM
dr.fixit's Avatar
The cylinder that raises the roof located behind the passenger seat. I need to see how it is mounted so I can repair mine. Thanks for your help.
Old Jul 12, 2016 | 02:36 PM
cjd777's Avatar
DR, the mount is really a couple of pins, so the ram can pivot. Check the three screws on the plate that holds the outer pin. As for the electrical connection.
Can you get the little screw out? It's a torx fitting, very small as you can see.
Wayne
Old Jul 12, 2016 | 03:35 PM
dsnyder586's Avatar
I'll do some dismantling this afternoon and see what I can find.
Old Jul 13, 2016 | 07:57 AM
djhaydel's Avatar
Go to Jag Repair Site, will have all the information you should need and some.
JagRepair.com - Jaguar Repair Information Resource
jomo
Nov 14, 2023 09:33 PM
sg18438
May 23, 2016 02:48 AM
croppy
May 9, 2016 12:07 AM
mvivio
Apr 30, 2016 08:25 AM
Kaeghl
Apr 22, 2016 04:43 PM
