I know what I'll be doing this weekend!!!
Old May 30, 2013 | 07:16 PM
Veteran: Navy
Default I know what I'll be doing this weekend!!!
oh yeah can't wait to install these - been hell having to drive with the top up these last few weeks!
Old May 30, 2013 | 07:40 PM
Nice one Steve, hope all goes well
Old May 31, 2013 | 10:39 AM
RCSign's Avatar
Steve go to Gus's web site
/JagRepair.com - Jaguar Repair Information Resource
Here has a good step by step procedure with photos. I was a great tool for doing the job. I did mine took about eight hours including installing the relief valve. Seriously think about adding the relief valve or resistor, there's plenty of information about both on the forum.
Old May 31, 2013 | 11:16 AM
Veteran: Navy
Doug - thanks for the reminder and link to Gus's site - just printed the procedure for reference to make the swap.
Old Jun 1, 2013 | 12:42 PM
Veteran: Navy
3.5 hours and cylinder hoses replaced, tested sat not to replace the rear seat and side panels - hell yeah - happy happy joy joy!!!!
Old Jun 1, 2013 | 12:58 PM
Well done! Time for a beer.
Old Jun 1, 2013 | 01:16 PM
SeismicGuy's Avatar
That sounds like record time. Were there some shortcuts you discovered or improvised to be able to do the job that quickly?
Doug
Old Jun 1, 2013 | 01:57 PM
Veteran: Navy
I only had to replace the 4 cylinder hoses but I ran the new into place before removing the old - so it was just a matter of disconnecting old and reconnecting the new - even screwed up and had to come back to the forum - JTIS says bottom hose of pump rear connector goes to bottom connector on cylinder when top hose goes to bottom connector - but all good and working - now cleaning the seats and side panels before reinstalling and realigning the rear quarter windows to clear the slight gap when windows are up.
Old Jun 1, 2013 | 03:37 PM
SeismicGuy's Avatar
So you didn't need to do the latch hose? I guess that is the one that takes hours to address.
Doug
Old Jun 1, 2013 | 04:01 PM
Gus's Avatar
Gus
Did you find this? Link JagRepair.com - Jaguar Repair Information Resource
Old Jun 1, 2013 | 04:12 PM
Veteran: Navy
Doug - no, latch hoses were replaced just before I bought it.
Gus, - yes went to that link first but all that opens is the title no diagram, so I opened the JTIS and followed most of what it said until I ran into the snag. I did a search on the forum and someone had posted a pdf of the hose connections so all is good.
Old Jun 1, 2013 | 04:16 PM
Veteran: Navy
now to detail her and all will be good!
Old Jun 1, 2013 | 08:01 PM
Gus's Avatar
Gus
Sorry it did not work for you. I will check the link and see if I can find the cause. Enjoy the top down.
Old Jun 1, 2013 | 09:44 PM
Sentinelist's Avatar
This is me, circa next week! Exact same scenario- glad to see this and can't wait to be in the same boat. Congrats on the job well done. Will use the links in here.
I haven't even driven it in more than a month because the top wouldn't latch in the process- one of the other 4 hoses burst in the back as it flopped down on top of the windshield, then passed out. Been running it once a week to keep it lubed.
Old Jun 2, 2013 | 06:56 AM
Veteran: Navy
Chris - it's pretty straight forward job. If I remember your post - you have the four hoses and the pump - so the removel of the pump is already done. Something else - The JTIS procedure has you remove the rear seat and seat back. I honestly think this step can be skipped - just remove the seat belt anchors at the top of the seat back and then you should be able to pull the linning from behind the seat to route the hoses from the passenger side to the drivers side. It's a little tricky putting the side panels back in this way but it may be a little less work for you. In my case, I did remove the seat/seat back and gave them a good cleaning before I reinstalled.
also - here is the diagram for the hose connections I found on the forum
File Type: pdf
emilime75
XJ XJ12 ( X305 )
Oct 19, 2015 09:55 PM
dmatthewman
Sep 30, 2015 10:10 AM
stephen.travers1
Australia - Queensland
Sep 30, 2015 05:28 AM
Vector
US Lower Atlantic
Sep 28, 2015 11:08 AM
N3yyz_XJR
Sep 27, 2015 11:26 AM
