Ignition switch door
So... is the door on the ignition switch that closes when you remove your key supposed to close ALL THE WAY... mine closes, but if I shine a light on it and look it seems to not be closing all the way - there is a gap at the top?
The door (or cover) seems to close and cover around 60-70% of the opening, but not all of it --- is that normal or should it completely cover the opening? Can someone take a look at theirs and let me know?
The reason I ask is that I am trying to trace down a small parasitic drain on my battery (it shows around 56ma after an hour or so and I think it should only show 30ma).
Thanks for your help!!
I've read a number of posts indicating it should close, suggestion was a little lube of choice. I looked at mine and there is no flap, they key actually pushes a post in, this post does not come all the way flush when the key is removed, fyi
FS[Western US]: XJS Lock Set with Keys- Doors, trunk, glove, gas, and ignition
XJsc-guy
Nov 23, 2015 01:56 PM
kabs3012
Sep 12, 2015 10:40 AM
1964Daimler
Sep 9, 2015 11:28 AM
