Ignition switch loose???
Old Jul 5, 2013 | 09:39 PM
deelli's Avatar
Default Ignition switch loose???
My XK8 ignition will sometimes not turn the car off...there is play in the tumbler it seems. I bought another one from Ebay and when I received it, there's the same play in the off position. Wondered if this is a common problem that the XK's and XJ's have with ignition switches (maybe should have tried to source a new tumbler).
Old Jul 6, 2013 | 03:52 AM
I've never found much difference in the 'feel' of the ignition key movement or had the issue you describe on any of the XJ's or XK8's I've owned.
Is the play in the Lock Barrel (item 9) or the Ignition Switch (item 4)?
aholbro1
Dec 29, 2024 06:46 PM
rentzoo
Nov 10, 2015 04:56 PM
Poet
Oct 6, 2015 09:40 PM
Tim Goz
Sep 17, 2015 09:11 AM
1964Daimler
Sep 9, 2015 11:28 AM
