Improving the shifts on a ZF 6 speed.
Old Jan 8, 2011 | 11:03 PM
growler's Avatar
Default Improving the shifts on a ZF 6 speed.
Just though I'd post how I got my tranny shifting a lot better. I cleaned my MAF Sensor. Yep finally did it after whinning about it over the Max Performance forum. It was slipping around during acceleration pretty badly and I really can't believe it was that easy. Oh well.
Old Jan 9, 2011 | 12:17 AM
H20boy's Avatar
Did you also do a hard-reset after the MAFs, mine was all kinds of goofy RPMs until I did it...in essence, starting from scratch.
Old Jan 9, 2011 | 01:49 PM
Reverend Sam's Avatar
How did you clean it?
Old Jan 10, 2011 | 02:28 AM
H20boy's Avatar
I removed it from the air pipe and air filter box, placed it on the floor of the garage atop a towel, and used MAFS cleaner (only) in short, repeated bursts directly into the unit from the TB side, letting it drain outward away from the wires. Did that about 5 times, let it dry for a few minutes, then reinstalled. Don't forget the little heater wire on the side too.
Old Jan 11, 2011 | 10:34 PM
growler's Avatar
I didn't reset it. I did just as H2O discribed. So much smoother now. Although She's wrapped up the garage right now and the temp here is 3!
Old Jan 12, 2011 | 03:47 PM
You're probably in one of those countries where ice melts at 3 degrees, aren't you?
hkmcmast
Nov 29, 2015 06:56 AM
Johnken
Oct 2, 2015 10:12 AM
Poet
Oct 2, 2015 09:00 AM
hughey
Oct 2, 2015 05:17 AM
