Increased my HP 10% in 5 minutes and at no cost
Old Mar 26, 2025 | 10:30 AM
pcolapacker's Avatar
Default Increased my HP 10% in 5 minutes and at no cost
Guess how. Hint: Did after replacing all the heater hoses.
Old Mar 26, 2025 | 12:56 PM
Dr. D's Avatar
You removed the slack in the throttle cable so that the throttle position opens to 100%.
Old Mar 26, 2025 | 01:21 PM
Good job. Next hint was going to be required a zip tie.
Old Mar 26, 2025 | 02:30 PM
Jon89's Avatar
All owners should do this. It does indeed make a very noticeable difference....
Old Mar 27, 2025 | 08:00 AM
Zspot's Avatar
Is this an easy mod? Any links to share?
I am intrigued.
Old Mar 27, 2025 | 09:24 AM
Kuddlesworth's Avatar
I am intrigued.
Pretty easy, on the drivers side you can find the throttle cable in the engine bay under the corner plastic cover, unlath the little plastic cover. Connect an OBDII reader and look at the throttle position, adjust it so it's at 100% when at full throttle no more no less otherwise you will idle high.
Old Mar 27, 2025 | 09:56 AM
Jon89's Avatar
I believe there is a video in the "sticky threads" section showing you exactly how to do this. Takes less than 90 seconds to do....
Old Mar 27, 2025 | 05:00 PM
baxtor's Avatar
I am intrigued.
Not being pedantic but it is NOT a mod, it is a regular maintenance task, albeit a very occasional one.
Old Mar 27, 2025 | 07:31 PM
Stumpy's Avatar
The OP is correct, sadly others with 4.2 engines listed in their sigs are not
The 4.0 and 4.2 versions have different throttle systems and adjustment procedures. Please refer to JTIS for your year.
You do not need to do this on the 4.2- as you can train the ECU the actual throttle pedal positions (it is fully digital/motorised) - without touching the cable.
If you do adjust the cable on the 4.2 you need a special adjustment tool and should also carry out the throttle position training to ensure you achieve 100% throttle opening.
The 4.2 throttle position training should also be carried out if you disconnect the battery etc.and need to reset the door window memories. It is listed in the 4.2 battery reconnect procedure.
I have checked the cable on my 2004 and the adjustment is correct, there is meant to be a certain amount of slack in the 4.2 system for correct operation.
AZDoug
Dec 21, 2024 08:45 AM
edankeven
Apr 3, 2015 04:47 AM
slmskrs
Jul 19, 2013 10:12 PM
macdoesit
Mar 27, 2013 04:09 AM
