Injector O-Rings
Old May 12, 2014 | 12:20 PM
Rezzz's Avatar
Default Injector O-Rings
I am in the process of replacing the valley hoses and securing all the gaskets and O-rings. I have a couple questions I would like some help on if someone has the answers it would be greatly appreciated. I searched older threads but did not find anything relevant.
1) There are 16 injector O-rings that I have priced them and the best I can do is about $130.00. Is there a Ford/Lincoln matching part number for less?
2) There are throttle body gasket and induction elbow seal are these available as a Ford/Lincoln part?
3) A multitude of O-rings for fuel pipe, fuel cross over and fuel Pressure regulator. Anyone have Ford/Lincoln numbers for these?
Old May 12, 2014 | 04:27 PM
Gus's Avatar
Gus
I replaced my intake manifold and used the same “O” rings and gaskets just used a good quality silicone lube. You know that you can have your injectors rebuilt. This is a link on what I did.
Old May 12, 2014 | 05:07 PM
The Coupe's Avatar
For about the same price as the o-rings you're sourcing, you can get a high-quality ultrasonic cleaning of your injectors, pre and post flow-testing, AND all new o-rings.
The vendor is Injector RX in Houston. A great service. I used them two years ago, and was very happy with the results.
You can find my thread on that service HERE. Good luck.
Old May 12, 2014 | 05:10 PM
auburn2's Avatar
What year and model car? For my 2001 XKR Rock Auto has the injector orings for $2.94 per injector.
Old May 12, 2014 | 05:16 PM
WhiteXKR's Avatar
There is an ebay supplier that sells a complete injector o-ring kit for your car, including replacement strainers for about $33. See V8 4 0L Jaguar Fuel Injector Service Repair Kit O Rings Seals Filters | eBay
Old May 13, 2014 | 07:23 AM
Rezzz's Avatar
1999 XK8 but the motor is a 2003 replaced by the dealer under warranty
Old May 13, 2014 | 11:55 AM
WhiteXKR's Avatar
If you order the ebay kit, make sure you then get the 4.2L version!
Old May 18, 2014 | 10:19 AM
aode06's Avatar
You can clean your own injectors very good.
I remove the injectors,so the engine will not hydro lock.
Place a rubber hose on the injector end.
Fill the hose up with fuel injector cleaner.
Blow on the hose,while using a battery and wire setup,to pulse the injector,until all the PURE cleaner is gone out the hose.
Works every time.
Old Oct 15, 2014 | 03:56 PM
brgjag's Avatar
you have to put silicon on the orings before you put it all back together? What kind of silicon?
Old Oct 15, 2014 | 04:53 PM
Gus's Avatar
Gus
A good quality silicone.
Old Oct 16, 2014 | 01:36 AM
sheddist's Avatar
For those of us in the UK an outfit called polymax can supply appropriate O rings. Probably somewhere in the the US too.
Anyone able to put together a list of O ring sizes?
jospolice
Oct 2, 2015 07:16 PM
reb1999
Sep 26, 2015 08:41 AM
SD96XJ6L
Sep 25, 2015 10:53 PM
apexjag
Sep 25, 2015 08:38 AM
