Intake duct pulling off throttle body
Old Oct 16, 2013 | 11:53 AM
theweeb's Avatar
Default Intake duct pulling off throttle body
2005 XKR, twice this month I have had the intake duct pull off of the throttle body, which creates a restricted performance state due no doubt in the difference between the front air flow sensor and the (barometric air pressure?) sensor at the throttle body.
The first time I thought it was a fluke, and simply jammed the duct back on, and tightened down the strap clamp. The second time, I broke a cheap screwdriver (girfriend's) tightening it.
Way back in the day, I had a Mustang with a 302 that would do this, turned out one of the motor mounts was ripped, causing the engine to flex under torque and thus pull away anything attached that did not have play.
Thoughts on why this is happening? Remember, the only stupid question is the one not asked....
Old Oct 18, 2013 | 08:06 AM
aode06's Avatar
You can unbolt the air box and just let it rest to give it some flex if you think that's the issue.
Mine turned out to be motor mounts.
Old Oct 18, 2013 | 09:17 AM
BobF's Avatar
+1 on the motor mounts. My 99 XK8 had a failed passenger side mount that broke the airbox to fender attachment (rubber).
Old Oct 18, 2013 | 10:17 AM
Jon89's Avatar
Wow. Good to learn what broken motor mounts can do. Thanks, guys....
Old Oct 19, 2013 | 03:12 AM
How exactly did the Mounts fail?
Breaking up at the rubber top / the castellated joint or by the gel leaking out?
clubairth1
30
Sep 3, 2025 04:38 PM
Gus
Oct 15, 2019 12:29 PM
mrplow58
Sep 9, 2015 11:27 AM
1100me
Sep 7, 2015 06:26 AM
