Interior boot open button and remote button don't work
Old Oct 3, 2014 | 06:33 AM
looops's Avatar
Default Interior boot open button and remote button don't work
Hi all.
The interior boot open button and remote button don't work. It's not in valet mode as when it is in valet mode and I press the release button the display tells me off.
I've put a voltmeter on the connector and there's zero volts when the button is pressed. I've checked the fuses in the boot and the drivers side.
Any other idea?
Thanks and happy Friday to you all.
Old Oct 3, 2014 | 11:54 AM
5V1900's Avatar
Originally Posted by looops
Hi all.
Any other idea?
Have you tried using the key to open the boot ? This resets (cancels) the valet mode, just in case it is in effect whether or not you have pressed the valet button.
Old Oct 3, 2014 | 12:02 PM
looops's Avatar
Yes used the black key to open the boot many times.
Old Oct 3, 2014 | 12:10 PM
jimbov8's Avatar
Just a hunch Looops, as your problem is to do with the electrical side of the operation, look at the loom that goes from the boot to the boot lid. You may have a broken wire in that part.
Does the button on the boot lid work or not?
I can't remember if there is a relay in the boot or not, but may also be worth a check.
Hope this helps,
Jim
Old Oct 3, 2014 | 12:30 PM
looops's Avatar
Thanks for the idea but this model doesn't have a boot button. The actuator is being the rear light so no wiring to the boot lid at all.
Old Oct 3, 2014 | 12:46 PM
jimbov8's Avatar
Ok Looops, attached is the electrical diagram for your car, check the connections to the security module and go from there.
File Type: pdf
Old Oct 3, 2014 | 01:54 PM
looops's Avatar
Thanks for that. Either there's a break in the orange wire from the control module or there's some logic problem stopping it energising.
Old Oct 3, 2014 | 03:23 PM
Felipe Pr's Avatar
Do you get a message "Boot open"? That happened to mine, 97 XK8 and it was a faulty micro switch. Changed it and problem resolved.
Old Oct 3, 2014 | 03:24 PM
looops's Avatar
Only when the boot is actually open so not that. Thanks for the idea though.
BrentGardner
29
Dec 16, 2024 12:13 AM
fast40driver
Apr 19, 2024 07:24 AM
johnnie ryall
Oct 19, 2015 09:44 PM
Ziggybeben
Aug 30, 2015 02:09 PM
Andrew McVey
16
Aug 27, 2015 07:21 PM
