Interior refresh
Old Oct 20, 2013 | 10:31 PM
dsnyder586's Avatar
Default Interior refresh
Hi All,
I am going to refresh the interior and redye the seats as well as the armrest. (I purchased the leather for the armrest in a different color, and am going to dye to match)
Any tips? I will be spraying the leather with an airbrush and will mix my own water based dye. I will be following up with a matte finish clear coat and need plan on many coats to insure a long life of the dye job. I have heard that you can fill in the cracks in the leather with household caulking- any thoughts on that?
I want to try and finish it so that I can use cleaner and NOT have the dye come off- any suggestions?
I will take pics and add them to this thread as I get along- I plan on about a week to finish.
One other thing- how can I get my carpet clean without taking it out and what cleaner is suggested by folks?
Thanks in advance for your assistance!
Old Oct 21, 2013 | 10:36 PM
dsnyder586's Avatar
OK...
I prepped the seats/armrests and center console for dying yesterday. Today I laid down 4 coats of color and will let them dry overnight before I spray the topcoat. I watched a video that said to use gloss for the first coat or two because it is much stronger, then matte finish for the finishing coats. Anyone here tried that? I am trying to put enough clear topcoat to avoid rubbing off of the finish down the road. as this will be my daily driver.
I neglected to take pictures, but will endeavor to do so tomorrow an Wednesday as I am able. Anyone know how to remove fruit punch stains from carpet?
Old Oct 22, 2013 | 05:13 AM
SteveJacks's Avatar
Originally Posted by dsnyder586
OK...
Try oxyclean on the carpet stain, but try in an inconspicuous place first.
Did you use household caulk on the seats like you mentioned/asked?
Old Oct 22, 2013 | 07:18 AM
Jon89's Avatar
Fruit punch stains are difficult to remove on light-colored carpeting. I battled one for several years in the cargo area of a 2000 Lexus RX300 SUV that my wife drove years ago. Tried all sorts of tips and was able to tone it down quite a bit but never completely removed it. If your stain removal techniques do not deliver the results you desire, you may want to consider a carpet dye job....
Old Oct 22, 2013 | 09:49 AM
aode06's Avatar
caulking-easier to sand, I used that for the usual, I used bumper repair resin for my severe repairs.
Followed by two dye coats, i used duplicolor vinyl and plastic paint, and let dry 3 days, then two nice coats of clear.
Takes up to 5 days, not to be sticky, mask everything off, the clear will get into the air and stick to any and everything, it is not controlled as the paint is.
this is before the clear coat, so you can imagine how incredible the difference is, its like eating a steak or a cracker.
My father even asked to borrow the car, and did nothing but compliment the work.Took me bout a hour or so with the wet/dry vac to vacuum the dust from sanding the armrest, i used 320 then fine with a orbital for the bumper repair resin, hand sand with caulk
Old Oct 22, 2013 | 07:03 PM
dsnyder586's Avatar
Ok, I took a couple pictures after the second coat of gloss- here is what it looks like.
I am pretty happy so far, except for some small cracks I did not see. Hopefully I can get to them after I am done with as I have left over dye and finish.
Ignore the red dot it is my parking laser.
https://www.jaguarforums.com/forum/m...nger-21172.jpg
Attached Thumbnails Interior refresh-dsnyder586-105525-albums-garage-beast-5197-picture-gloss-coat-drivers-21171.jpg
Old Oct 25, 2013 | 07:13 PM
dsnyder586's Avatar
..and the finished product. If I had it to do again (and I may) I would have spent more time perfecting the prep work and using less coats. It looks good and is soft, which is what I was going for.
For perspective, there was a 3 inch rip in the driver's bolster and a few tears along with cracks everywhere. The center console was also ripped, but I ordered a new skin, put it on and dyed it at the same time with the seats and armrests.
all in 4 coats of color, 3 coats of gloss and 4 coats of matte. should have done 2 coats of dye, one coat of gloss and two coats of matte- lesson learned. I suppose if it gets cracks, I can repair them individually instead of doing the whole shebang. Will be taking it down to cars and coffee tomorrow morning as it is in perfect shape to do so.
Attached Thumbnails Interior refresh-dsnyder586-105525-albums-garage-beast-5197-picture-img-3493-21221.jpg
Old Oct 25, 2013 | 08:17 PM
Jag#4's Avatar
Truly an amazing transformation! Nice job.
Now that you're experienced, want to come do mine?
Old Oct 25, 2013 | 10:25 PM
dsnyder586's Avatar
Get yourself an airbrush and schedule about 5 days to do it right... sandpaper dye and clear cost me under $40 as opposed to $600 for new skins or seats.
I took the opportunity to clean the carpet, vinyl, door panels and replace some of the broken bits around the job as well. FYI- I used oxyclean laundry detergent on one of the seat belts to test and it came out CLEAN. Wish I took before pictures, it was a MESS.
Old Oct 26, 2013 | 07:52 AM
ccfulton's Avatar
Very nice, looks like new again.
Old Oct 26, 2013 | 08:07 AM
DevSpider's Avatar
You did a good job!
I heard that after a month or two of usage, the leather develops cracks in same spots as before. Keep us posted on how it wears over time.
bdboyle
Sep 16, 2019 05:58 PM
GGabriel
Nov 22, 2018 03:53 AM
MrWhite
Oct 1, 2015 01:43 AM
N3yyz_XJR
Sep 27, 2015 11:26 AM
42Ajd
Sep 26, 2015 07:04 PM
