iphone 4 music and blue tooth in 2001 XK8
Old Mar 10, 2011 | 08:06 AM
bassmania's Avatar
Question iphone 4 music and blue tooth in 2001 XK8
Trying to figure out the best way to add blue tooth and a connection for my iphone 4 to play my music in my 2001 XK8 premium sound. Any ideas???
Old Mar 10, 2011 | 08:23 AM
Glenn Barickman's Avatar
There is a "ton" on information on this subject in the forum. Start by looking in the FAQ at the top of this section and use the search tools. You will find most of the info. you need. Good Luck and let us know haw you are doing.
Old Mar 10, 2011 | 01:08 PM
H20boy's Avatar
whitexkr did a signal sensing, RCA switch in his car, and he posted some details about the product and how it was installed in a few threads over the last couple months. Not sure if you could get a 5mv ipod-compatible car adapter hardwired that will use the iphone's dock line-out, and charge it, then you could utilize the line-out signal to go into the RCA audio switch. I did this recently for a nano, not sure if the iphone would still apply in regards to that 12v charging/dock part.
Old Mar 10, 2011 | 03:25 PM
WhiteXKR's Avatar
Bsss-
This thread covers it pretty well. It needs a careful read to see what applies to your model year, but the info is there.
https://www.jaguarforums.com/forum/s...ight=bluetooth
My GVN 53 writeup (link is in my signature) also has additional info on adding the signal sensing switch to the stock Alpine.
The signal sensing switch for audio is pretty much plug and play (if you do not use a preamp), but the bluetooth will require some cable splicing for your model year.
You can also do both audio and bluetooth with wireless FM modulated or self contained solutions...audio quality is less, and they will not use the factory mute, etc. built into the car...but the installations are easier.
Dz1rfj
Jul 17, 2018 10:29 AM
picard
Oct 12, 2015 11:56 AM
picard
Sep 19, 2015 08:13 PM
Dz1rfj
Sep 16, 2015 03:44 PM
Celticblood
Sep 14, 2015 07:30 PM
