jaguar claimed field service action codes?
Old Apr 7, 2015 | 11:55 PM
loulollio's Avatar
Default jaguar claimed field service action codes?
Does anyone know what these repair codes stand for?? I199, S474, s501c, s484x, s499B, s841C
I thank you in advance. 2000 XKR Jaguar Convertible.
Old Apr 8, 2015 | 12:12 AM
Cambo's Avatar
Welcome to the forum, I've moved your post to the XK8/XKR section, this is the correct area for a 2000 model XKR.
When you get a moment stop by our new members area ==>> New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
Old Apr 8, 2015 | 12:18 AM
Cee Jay's Avatar
Uh oh, you're going to get yelled at by a Moderator because you posted in the X150 forum (2007-2015 Model Year) instead of the X100 (1997-2006 MY). The moderator will move it to the correct forum for you AND also yell at you for not first introducing yourself in the Newcomer Forum. Also, you are highly encouraged to add a signature block for your posts so members know what vehicle you have.
But until then, the site jagrepair.com has some info, I'm not sure if it's fully relevant.
Cee Jay's Avatar
Oops. I was too late, Cambo beat me to POST.
Old Apr 8, 2015 | 12:32 AM
Cambo's Avatar
Come on, I didn't yell...
Old Apr 8, 2015 | 09:15 AM
test point's Avatar
S474:
http://www.jagrepair.com/images/TSB/...20Breather.pdf
S499B:
warranty codes
Mr. Google is unaware of the others.
Old Apr 8, 2015 | 11:11 AM
xjrguy's Avatar
I199, I suspect is a typo. I999 would denote the Pre-Delivery inspection claim.
S474, Service Action to clean the Part-Load Breather and add to maintenance interval thereafter.
S501, Service Action to replace EGR transfer pipe for possible cracks.
S484, Service Action to inspect IPC, and replace back cover or IPC entirely.
S499, Service Action to inspect and/or replace frt lower wishbone bushes.
S841, Service Action to replace EVAP Vent pipe for possible internal corrosion/rust.
Cheers,
X_Type_South_Africa
Dec 9, 2015 05:37 PM
Fraser Mitchell
Oct 1, 2015 04:06 AM
thedugger1
Sep 24, 2015 05:32 PM
bhojav
Sep 5, 2015 01:19 PM
Vector
US Lower Atlantic
Aug 26, 2015 05:36 AM
