K-line or CAN or both
Old May 17, 2012 | 04:39 PM
RaceDiagnostics's Avatar
Default K-line or CAN or both
Can anyone say if the OBD2 port an a 2002 4.2 XK8 uses the K-line or CAN bus or both for diagnostics to the engine ECU.
Old May 17, 2012 | 05:52 PM
Stumpy's Avatar
The 4.2 (I thought introduced in 2003) data link connector uses 3 systems for communication:
CAN, SCP and Serial data link.
I believe K-line normally uses pin 7 for communication. There is no connection to pin 7 in the data link connector.
Old May 18, 2012 | 02:07 AM
The 4..2 came out on Q4 2002 in the UK, not sure about the rotw.
Well I was a bit surprised when I used my AE cable as it indicated that it was connecting using ISO-9141 which uses the K-line.
Are there any diagrams showing the obd topology or a list showing which bus is used for which module?
Old May 18, 2012 | 07:57 AM
WhiteXKR's Avatar
The topology is in section 21 here: http://www.jagrepair.com/images/Auto.../jagxk2003.pdf
Just FYI, the topology changed significantly with the switch from the 4.0 to the 4.2.
Old May 18, 2012 | 08:27 AM
Hmm, well thats odd, Ill have anothar play around with it tonight.
Old May 18, 2012 | 08:38 AM
steveinfrance's Avatar
My reader definitely uses the ISO-9141 protocol (on a UK car)
Old May 18, 2012 | 09:19 AM
avos's Avatar
What is the plan?
Old May 18, 2012 | 09:27 AM
This video shows just a few features, it also does lots of other stuff, dyno plots, 0 to 60, 0 to 100 timing etc. All data comes from the diagnostics port using a proprietary VAG protocol.
Since Kin now has a Jag I am thinking about adapting it, but it will be a fair amount of effort so there are no timescales.
It started life just as a boost gauge, that grew legs.
liquidA3 (8P Chassis) test run - YouTube
Old May 18, 2012 | 10:24 AM
avos's Avatar
Haven't mastered the onboard networks yet, but the Serial Data Link (ISO 9141) is used for Diagnostics at 10.4 Kbaud.
But I think the IDS is also communicating via the CAN bus to the ECU, as I can monitor that traffic, and the IDS gets much more data per second than via standard OBDII interfaces (so Kline then).
Xag
Jul 13, 2022 02:42 PM
NTL1991
General Tech Help
Oct 28, 2014 08:20 PM
