key cloning
Old Aug 3, 2021 | 03:03 PM
femacon's Avatar
Default key cloning
Help does anyone know if i can get a valet key cloned to main key ?I have valet key that works and main keys cut but not programmed.
Local dealer unable or unwilling to program and local Indie tried but failed to reprogram.Also any contacts with locksmiths that may be able to
clone vehicle is 1999 xk8 convertible.We are in the Mobile Alabama area.
Old Aug 3, 2021 | 03:31 PM
fmertz's Avatar
For a pre-2001 model, you need to check that the crypto chip built into the handle of the new key is the older Megamos 13. The 2001 and later system calls for the newer Megamos 48. Check with whoever made your new key. FWIW, these chips are available separately on eBay for a few $. Worst case, you have to dig out the old one (if there is one) and replace it. Then your Indie can try again.
Best of luck, keep us posted.
PS: I am aware of the possibility of cloning the older chips, but it is a locksmith thing, outside of the normal procedure.
Old Aug 3, 2021 | 03:45 PM
femacon's Avatar
How can i check see which transponder is in the keys i have??
Old Aug 3, 2021 | 04:14 PM
fmertz's Avatar
Check with whoever made your main key. It must be a key for a 98-2000 car. A key for a 2001 and later car will have the wrong chip.
agd
Aug 28, 2024 06:10 PM
Frog
Jul 20, 2022 12:36 PM
galenmcallister
Jan 14, 2021 07:45 PM
SirJohn
Oct 23, 2017 01:21 AM
jeremys
US Northeast
Jul 28, 2017 12:55 PM
