Knocking noise coming from rear
Old Sep 12, 2022 | 04:07 AM
W0ngu's Avatar
Default Knocking noise coming from rear
Hi,
Hoping to get some advice. I have a knocking noise which sounds like it is the rear of the car, UK Passenger side.
Only happens when going over bumps or accelerating from a standstill.
A frame bushes are new and replaced the shocks a few thousand miles ago with new upper foam mounts.
Bouncing the car stationary doesnt produce any noises and from what I can see under the car, everything looks to be fine.
Also had someone feel the lower shock bush whilst bouncing and nothing could be felt.
Car handles and drives fine, just a bit alarming hearing this from time to time.
Any ideas?
Cheers,
Ryan
Old Sep 12, 2022 | 05:53 AM
Jon89's Avatar
Could be worn-out rear sway bar bushings....
Old Sep 12, 2022 | 06:01 AM
MickeyR's Avatar
Exhaust hanger?
Old Dec 6, 2022 | 04:36 PM
W0ngu's Avatar
For anyone wondering about this, it turned out to be a loose bolt on the A frame.
when checking these bolts with a normal ratchet wrench it felt tight. when I got the breaker bar on them, one just started loosening with little resistance.
Retorqued all the bolts and no more knock!
Feel like an ****, but lesson learned.
Hopefully it helps someone else out in the future.
Old Dec 6, 2022 | 04:59 PM
Jon89's Avatar
No-cost fixes (except for the time involved) are always the best kind. Happy motoring....
Old Dec 24, 2022 | 12:19 PM
Shoreguy's Avatar
Veteran: Air Force
I was going to tell you to let your wife out of the trunk? lol Sorry couldn't help myself but, glad you figured it out
Cheers!
Andrew
Old Dec 24, 2022 | 05:40 PM
STLTHMSTA's Avatar
Here's a test.....Lock your wife and your dog in the trunk (boot) for a couple hours and see which one is glad to see you. TM
Old Dec 24, 2022 | 08:15 PM
Jon89's Avatar
I wouldn't want to put my dog through such misery....
harvest14
Jan 22, 2021 10:55 PM
Skid Mark
Aug 25, 2011 05:10 PM
wfd
Feb 23, 2011 05:34 PM
snoook
Feb 19, 2010 10:23 AM
