knocking noise xk8
Old Aug 16, 2012 | 02:19 AM
B5sem's Avatar
Default knocking noise xk8
Hi ,i wounder if any one can help me .
I have a 1999 xk8 last weekend while driving a noticed a knocking,tapping noise.
This happens when the car is warm ,not cold .
If i increase the revs ,the knocking becomes faster .
If i put the steering on full lock in both directions,the noise knocking stops .
Old Aug 16, 2012 | 02:33 AM
Default Knocking / Tapping Noise
(moved from Intro section to XK8 section)
If this knocking is coming from the front of the engine, don't drive it until you've investigated further. The early XK8's have a known issue with tensioners which can destroy the engine when they fail.
I know it's extremely difficult to describe a noise! Try to give an indication of whether it's from the engine, the suspension or the steering.
Old Aug 16, 2012 | 02:47 AM
B5sem's Avatar
Hi Graham
Thank you for your help .
I have done some reading up on the cam tensioners .
Would you have any idea why the knocking stops when on full lock ?
Also, i forgot to mention ,when on full lock with the revs increased (knocking stops ) but when i take my foot of the power ,engine stalls .
Old Aug 16, 2012 | 06:03 AM
That's an interesting combination of events! In summary it's:
1. vehicle stationary
2. in Park
3. knocking sound occurs with steering straight ahead
4. knocking stops on full lock
5. engine stalls at idling rpm
Although it's likely to be more than one issue (knocking and stalling), have you checked the engine mounts? These are a known weakness.
It may turn out to have nothing to do with the knocking but got to start somewhere on the list of possibilities.
mrplow58
Jan 21, 2024 05:53 AM
Razor
Aug 28, 2019 08:34 PM
roman_mg
Feb 8, 2016 01:30 AM
tsimms7
Sep 15, 2015 12:43 PM
robiwhan
Sep 4, 2015 10:43 AM
