Largest rear wheel and tire combination
Old Oct 14, 2013 | 11:48 AM
platinummaker's Avatar
Default Largest rear wheel and tire combination
Guys,
I am currently running black powder coated Astroid wheels on my black/black 98 vert. I want to stuff the widest wheels and tires I can on the rear. The Astroids are from my old XJR and are 8 inches wide. I can have the wheels widened to virtually any dimensions I request including offset/back spacing.I know this has probably been queried before but I would welcome any feedback. Thanks guys
Old Oct 14, 2013 | 04:44 PM
Gregfromuk's Avatar
I currently have 20" detroit alloys which are 11" wide :-)
They were on it when I bought it and it looks sweet!
Greg.
Old Oct 14, 2013 | 05:04 PM
DevSpider's Avatar
I think you may be able to fit up 12.5". However, on a rwd car, traction may become an issue, especially if you car does not have a limited slip differential. Even then, your tires will cost a fortune. But, it will look super cool.
Old Oct 15, 2013 | 11:00 AM
Krajcok's Avatar
I thought all 'performance' rims (detroit, paris, speang, etc) are all front 9J and rear 10J. How can be detroits 11J?
Old Oct 15, 2013 | 11:06 AM
SteveM's Avatar
You're correct, they're 10" not 11"
The tuning company Arden uses their 11" wide wheels on the rears.
Old Oct 15, 2013 | 11:31 AM
Gregfromuk's Avatar
Oh! My bad! It was dark last night when I measured them.
Old Oct 15, 2013 | 02:23 PM
SteveM's Avatar
Well wheel widths are measured on the inside of the lips, where the tire bead seats. This is the size that's stamped on the back of wheels. If you measure the outside lips then you'll get about and inch wider.
Old Oct 15, 2013 | 02:58 PM
Krajcok's Avatar
How about max wheel diameter? Did anybody try put 285/35/20 tyres?
Old Oct 15, 2013 | 03:25 PM
jima's Avatar
I put 295/30R20 on mine but they don't look right on the rims so I'm going back to 285/30R20 but hopefully better tyres than the Pirelli's (Dunlop SportMaxx RT).
Old Oct 15, 2013 | 04:10 PM
Gregfromuk's Avatar
I've got 285/30R20s on the back. I've got something right ! hehe
Old Oct 15, 2013 | 07:54 PM
enderle's Avatar
Default What I'm running
Originally Posted by platinummaker
Guys,
I'm running 245/35 ZR 20s in front and 285/30 ZR 20s in the back, getting these to fit pretty much required a shoe horn. I might be able to go a little wider in front but back is pretty much at the limit without hitting the lip or flaring the wheel well.
Old Oct 15, 2013 | 11:53 PM
avos's Avatar
Am using 295/35/20, which is not only wider but also larger in diameter. Pending on how much you have lowered your car, this is already the limit and had to already bend the inner fender lip.
Old Oct 16, 2013 | 08:57 AM
Krajcok's Avatar
AVOS, what kind of rim (and offset) do you use? Do you have spacers?
Old Oct 16, 2013 | 11:09 AM
avos's Avatar
Its that standard 20" Montreal wheel, and no spacers, which wouldn't work as you then would hit the inner fender lip.
Old Oct 17, 2013 | 04:25 PM
Thanks for all the input. It appears the consensus is that the max wheel width that will fit is 10 inches
Thanks again
Old Oct 18, 2013 | 07:16 AM
Krajcok's Avatar
Well, user Frog uses (?) 15mm rear spacers with 20" rims and he has no interaction with rear fender:
https://www.jaguarforums.com/forum/x...spacers-87529/
As far as I know each of 20" BBS has the same offset: 25 (10J) rear and 30 (9J) front.
Old Oct 18, 2013 | 01:23 PM
avos's Avatar
Well, user Frog uses (?) 15mm rear spacers with 20" rims and he has no interaction with rear fender.
But he hasn't my size of tires...
Old Oct 18, 2013 | 02:54 PM
Krajcok's Avatar
Right. Your 295's protrude 5mm, so you could use 10 mm rear spacers.
Old Oct 19, 2013 | 12:21 AM
avos's Avatar
I have 295/35, not 30, so they are no only wider but also larger in diameter.
hunter34
19
Sep 14, 2022 11:09 PM
PMKimpton
Aug 3, 2019 08:22 PM
KarimPA
Sep 12, 2015 08:15 AM
RaceDiagnostics
Sep 7, 2015 07:28 AM
innzane
Sep 2, 2015 10:08 AM
