Later Model front bumper upgrade
Old Feb 28, 2013 | 11:45 AM
platinummaker's Avatar
Default Later Model front bumper upgrade
All,
I have a 98 black/black vert that has just had major body modifications done to the front end due to my teenage daughter backing her Cherokee into it yesterday. The body shop has indicated that I will need a new hood, bumper surround, grille and assorted ancillary parts. I've searched but have been un able to determine if a later (05) front bumper and grill would be a bolt in modification since the parts have to be replaced anyway. Anyone have any experience/recommendations? I am also contemplating an XKR hood as well.
Thanks much
Old Feb 28, 2013 | 12:03 PM
Frog's Avatar
Not sure about the bumper, but the XKR hood will definitely fit. The only difference is the vents.
Old Feb 28, 2013 | 01:12 PM
steveeasy's Avatar
Hi,
Try the link below. This business has different design nosecones that should fit an early XK8.
Paragon Design UK Ltd
Best Wishes
Steveeasy
Old Feb 28, 2013 | 05:49 PM
ccfulton's Avatar
It will fit with some minor modifications.
The biggest difference is that the fender liners are not wide enough, so you will either need to get them along with a salvage bumper or make some extensions.
Old Mar 1, 2013 | 01:59 AM
XKRacer's Avatar
Easy fit done it over 60 times
Thanks for the heads up Steve
Also IMO the biggest difference is where the bumper bolts just in front of the hood, you will need some 5/8ish (16mm) spacers in 4 places, the ends bolt up the same so do the fenders. Yes Chaz is right you will need the wheel liner extensions and a new/different under tray. You also need different fog lights
Old Mar 1, 2013 | 10:28 AM
Default Late Model Front Bumper upgrade
Thanks so much for the input guys! I think I'll start the parts collection and see if I can't make it work. Thanks again
dsnyder586
Dec 29, 2024 07:39 PM
Dz1rfj
Jul 17, 2018 10:29 AM
Dz1rfj
Sep 16, 2015 03:44 PM
prettydaim
Sep 4, 2015 09:13 AM
SouthernGypsy
Sep 3, 2015 10:54 AM
