Leak on air conditioning
Old Sep 21, 2020 | 05:47 PM
ieccpa's Avatar
Default Leak on air conditioning
Need to repair a leak on fluid line of the air conditioning that goes behind the motor to the compressor. Any suggestions
Old Sep 22, 2020 | 06:57 AM
michaelh's Avatar
Do you mean this one (11)?:
Whereabouts is the leak?
Old Sep 22, 2020 | 07:27 AM
Rtoy42's Avatar
Any leak in the AC system will require replacement of the leaky part and pulling the system down to at least 25 inches of mercury. Then turn off the valve from the vacuum pump and allow the the vacuum to suck in the new refrigerant. You will need a scale under the refrigerant can to put in the proper amount. Do you have a guage set for monitoring pressures and to connect the refrigerant can? Unless you have the tools I would recommend taking it to a good shop. Good luck!
Old Sep 22, 2020 | 09:10 AM
ieccpa's Avatar
norfskate
Jul 18, 2018 03:36 PM
RaceDiagnostics
Jun 24, 2017 01:56 PM
Sonic
Dec 5, 2013 04:13 PM
L80ous
Feb 20, 2013 04:52 AM
Camgear
Jul 13, 2010 04:09 AM
