Leather Seats
Old Jan 28, 2025 | 11:23 PM
BLKLSTD's Avatar
Default Leather Seats
I saw an advertisement for new leather seat covers at a rather low price. The price has me questioning the legitimacy. I'm curious if anyone has purchased anything or heard anything about them. It's Lseat.com. They have both front seats for $350.00 . The pictures they show don't look too bad. Might not be stitched quite as good. but for the price, I'd give it a try. So many scammers nowadays.
Old Jan 29, 2025 | 04:57 AM
there have been a few forum members use Lseat - do a quick forum search using Lseat as the keyword and you will find 22 results in the XK8/XKR and over 80 total
Old Jan 29, 2025 | 05:17 AM
sanchius's Avatar
^^^^^ This.
Lseat.com has been discussed here many times in the past, search is your friend here.
Here's how you use this site's search function:
Simplest: Put "Lseat" into the Search Threads dialog box in your upper right hand corner,
Or: Use the Threads pull down menu in your URHC, select "Advanced", then search for "Lseat" in this forum + select "Search entire posts" + select "Show results as" Posts, which gives you this: https://www.jaguarforums.com/forum/s...rchid=15655751
Old Jan 29, 2025 | 07:24 AM
zray's Avatar
re the advanced search function; it does help in most / many cases to limit the search to just the X-100 forum. Which can be done by deselecting “search all forums” category and scrolling down until you come to the X-100 category and then check that option.
Z
Old Jan 29, 2025 | 08:37 AM
wymjym's Avatar
Search is your friend, yes some have purchased and they were satisfied.
wj
Old Jan 29, 2025 | 09:24 AM
BLKLSTD's Avatar
Default Search
Z
I've never had much luck with the search feature.
Old Jan 29, 2025 | 09:27 AM
BLKLSTD's Avatar
Default Search
Originally Posted by sanchius
^^^^^ This.
Many times I have tried using the search feature. Never came up with much. Thank you for your reply and instructions. Maybe I'll try again.
Old Jan 29, 2025 | 10:29 AM
Jag#4's Avatar
Another way to search is to use google. "lseat jaguar forums"
I usually get better results this way plus you will see Jag-based sites as well with that search. This forum will come up first.
Old Jan 30, 2025 | 12:34 AM
Throwback's Avatar
Can confirm the LSeat.com covers are real and not a scam, pretty good quality items and matchless at that price. The wrinkles have disappeared over time, hot days in the sun are your friend . Plus a bit of heat gun and steamer action will speed things along.
odpuskas123
Mark V - X 420G
Feb 18, 2025 07:23 AM
Arminius
Aug 22, 2023 12:49 PM
WatchGuy
Nov 11, 2022 05:01 PM
steve_k_xk
Sep 17, 2021 11:34 AM
bcucharternet
Oct 30, 2019 10:04 PM
