Left Brake Light 2001 XK8 Conv
Old Sep 1, 2012 | 11:34 AM
2001XK8Ragtop's Avatar
Default Left Brake Light 2001 XK8 Conv
left brake light out, tried two different bulbs fuse is working all other bulbs are working, cant pass inspection like this!!
what should i try next?
Old Sep 1, 2012 | 03:46 PM
MRomanik's Avatar
Veteran: Air Force
check your ground wire (black). a common problem.
Here's a link for a fix.
1997 XK8 Tail light assembly - ground melted - with pictures! - Jaguar Forums - Jaguar Enthusiasts Forum
Old Dec 23, 2012 | 02:01 PM
GoBlue97XK8's Avatar
Hi-New Memeber,trying to diagnois rear brake lights issue on my '97 XK8,I have read of 2 possible fixes-brake light switch under pedal and bad ground.Confused because brake lights do not work at all when key is NOT in ignition,with key in aux or car running the "dummy light"(3rd light) works as do 1 of 2 brake light bulbs in each lighting harness.The same bulb is not working in each bulb harness(if looking down into trunk its the inner most bulb on lower row,all the other bulbs in their respective harness are working as should)Also cant figure out how to post this question in my own thread..
Old Dec 25, 2012 | 07:08 PM
goblue97xk8 - If it is the inner most on the bottom row - the rear fog light - should be a button on center console to turn them on
toronadomike
Jan 22, 2026 10:13 PM
Sprayall
May 30, 2021 08:13 AM
Shawn Svacha
Nov 4, 2019 02:47 PM
brgjag
General Tech Help
17
Sep 9, 2015 07:34 AM
Sprayall
Sep 3, 2015 07:49 PM
