location of VVT solenoid on 2000 Jaghuar XK8
Old Nov 6, 2017 | 11:43 PM
jbonilla's Avatar
Default location of VVT solenoid on 2000 Jaghuar XK8
location of VVT solenoid on 2000 4.0 XK8
Old Nov 7, 2017 | 01:17 AM
phanc60844's Avatar
? what about it?
Old Nov 7, 2017 | 02:21 AM
jbonilla's Avatar
my jag has a severe engine noise and I was informed that if the VVT solenoid when plug or non-operational it will oil starve the cam and timing chains (primary and secondary. I wants to know where is the solenoid is to check it and if bad replace it
Old Nov 7, 2017 | 02:58 AM
phanc60844's Avatar
depending on the engine it either sticks out of the cam cover at the front of the engine or out of the timing chain cover on both sides
Old Nov 7, 2017 | 04:15 AM
jbonilla's Avatar
Thank you I will check tomorrow morning
Old Nov 7, 2017 | 06:39 AM
fmertz's Avatar
Another thought: don't even start then engine before you know if the secondary tensioners have been replaced...
Old Nov 7, 2017 | 06:58 AM
BobRoy's Avatar
+1
Do not start the engine. Pull the cam covers off and check the secondary tennsioners and timing chain. If it is the tennsioners and it only jumped one tooth you can save the engine. If it jumps two teeth the valves will hit the pistons.
The pictures below are from a car I bought that the local shop keep on cranking the engine trying to diagnose the problem until it jumped the second tooth and you can see the results. I put a new head, piston, and rod bearings to repair the damage.
Old Nov 7, 2017 | 07:16 AM
BobRoy's Avatar
I had an after thought.
I see you from my area and new to the forum.
How long have you had the car and some history.
Did the car ever overheat? If it overheated dropped valve seats will make a sound that you might think it was starving for oil.
I know of a car in our area that overheated and hope your car isn't it.
Old Nov 7, 2017 | 08:41 AM
NBCat's Avatar
+1 on removing the cam covers to inspect the secondary timing chain and tensioners.
Is the MIL on? If so, what DTCs are stored?
billbjork
Oct 30, 2021 09:18 PM
Rob Reilly
Apr 12, 2018 04:58 PM
Don B
General Tech Help
Nov 9, 2015 12:59 PM
Skid Mark
Nov 28, 2011 11:06 AM
