low coolant
Old Aug 3, 2011 | 09:42 AM
pophen's Avatar
Default low coolant
In a previous thread I read that the float in the expantion tank could stick and give a low coolant message. My problem: after a 50 mile all highway trip stopping and starting on the local roads produced the warning. Riding on level roads no warning. I'm guessing the float wasn't stuck. Picked up some 50/50 mix at a A&P I passed. After the engine cooled down I opened the expansion tank. I could see fuid in the tank and it only took about 4 oz to bring it close to full. Drove the 50 highway miles back home. This morning I checked the expansion tank and it was at the same level I filled it to. At no time did the temp. guage go above the normal mark. Question: is the sensor that sensitive? Will 4 oz low in the cooling system produce a warning? I checked every placed I parked at home and could find no coolant on the ground. 2 years ago I had the system drained and new thermostat installed. Ideas. Jack
Old Aug 3, 2011 | 09:52 AM
K.Westra's Avatar
I had the same thing happen to mine. The sensor seems to be that sensitive.
Old Aug 3, 2011 | 10:22 AM
Skid Mark's Avatar
Mine was doing that for a while and I would put about 6oz in. Seemed like a nuisance Then one day the warning came on and I put in about 18oz, and it's been that way ever since. Don't know what changed, but I like it.
Old Aug 4, 2011 | 09:01 AM
pophen's Avatar
Default low coolant
Thanks guys! Your replies give me some piece of mind. Going to keep the 50/50 mix in the trunk for a while just in case. Jack
Old Aug 6, 2011 | 11:02 PM
gchin's Avatar
So far, I keep a pint bottle of 50/50 dexcool equivalent and a quart of engine oil in the trunk at all times.
Wahooesprit
Dec 23, 2019 02:01 PM
duecedriver
Dec 25, 2015 11:47 AM
Tipptone
Sep 16, 2015 07:39 AM
Johnken
Sep 15, 2015 05:46 PM
1100me
Sep 7, 2015 06:26 AM
