Lower Coolant Hose Won't Fit
Old Nov 29, 2024 | 04:47 PM
pcolapacker's Avatar
Default Lower Coolant Hose Won't Fit
2002 XK8. Tried to replacel lower radiator hose with Üro MJA4515AD. Hose end to radiator is too small. It's ID is 1 5/8. The ID of the original is 1 3/4. Tried heating to stretch and lubricant and still no go. The original was two hoses spliced together. I thought the splice was to repair a leak. Guessing now maybe spliced to make it fit. I think the radiator is original. Anyone else have this issue?
Old Nov 29, 2024 | 05:11 PM
Jon89's Avatar
Stay away from URO hoses. Extremely poor quality. Prone to leaks and fast degradation....
Old Nov 29, 2024 | 05:15 PM
michaelh's Avatar
Although it may indeed be just a duff hose from Üro, note that the ends of MJA4515AD have slightly different bores (the OEM I fitted certainly has) the radiator end being the larger.
Its shape almost allows it to be fitted either way round.
Old Nov 29, 2024 | 06:36 PM
Yes. Figured that out.
Old Nov 29, 2024 | 06:39 PM
I stay away from URO if I can. Only option on RockAuto when I ordered. Recommended brand?
Old Nov 29, 2024 | 07:49 PM
zray's Avatar
have you tried ordering from sngbarratt.com
Old Nov 30, 2024 | 10:04 AM
Originally Posted by zray
have you tried ordering from sngbarratt.com?
They had Jaguar brand only on special order. Almost every parts seller only had URO. I bought Mackay brand. Never heard of but found some good reviews.
Old Dec 9, 2024 | 09:34 AM
Default Frustration continues!
The Mackay lower hose is the same 1 5/8 inch diameter where attaches to the radiatior and too small. I noticed the label says XK8 2002.5.
Old Dec 9, 2024 | 02:54 PM
michaelh's Avatar
Heritage has it:
https://parts.jaguarlandroverclassic...ttom-hose.html
...which means you should be able to get one via a dealership. OEM comes with new cobra clamps.
Old Dec 9, 2024 | 04:34 PM
Y2KJag's Avatar
This is interesting. I replaced every underhood hose on my car when I first got it. Unfortunately, lots of the hoses are URO-only. I noted that they were all slightly too narrow in diameter, but did fit with a bit of finessing. The Rein upper hose fit like a glove.
IIRC I also used a URO lower radiator hose and it fit OK. I did install an aftermarket radiator, but the car already had one. Being as had sat for 8 years I didn't want to risk anything. I wonder if you have some odd non-standard radiator.
Old Dec 9, 2024 | 08:33 PM
Default Update
Heated end of hose in a pot of water on the stove. That worked.
Old Dec 10, 2024 | 06:09 PM
zray's Avatar
another workaround is to heat up a hose end with a hair dryer, or if very careful not to overdo it, with a heat gun on low temp setting.
I used that method to get a 1/2” ID hose over the flare end of the stock ATF hoses, (formally going into the side radiator tank).
Z
Old Dec 10, 2024 | 08:28 PM
Z
I tried that first. Blowing on inside and out. Don’t think heat permeates all the way through thickness of hose.
Old Dec 10, 2024 | 09:02 PM
zray's Avatar
one has to go with the solution that works.
​​​​​​….all’s well that ends well…”
William Shakespeare
watto700
XJ XJ12 ( X305 )
Oct 10, 2023 09:07 PM
marvin.d.miller
Oct 29, 2018 09:12 AM
bburton
Apr 12, 2017 10:07 PM
AlfaVeloce
Nov 25, 2013 06:32 PM
K.Westra
May 1, 2012 06:14 PM
