Lower timing chain noise
Old Feb 21, 2011 | 12:29 PM
Skid Mark's Avatar
Unhappy Lower timing chain noise
I had the upper valve chains/tensioners replaced 6 mos ago due to a whirring metalic noise coming from the engine compartment. The noise has persisted, and I was wondering if it could be lower chain noise.
Thoughts?
Old Feb 21, 2011 | 06:20 PM
H20boy's Avatar
noises are very hard to communicate to others...any chance you can video w/ some sound with it? at least you 'll get some guessing.
Old Feb 21, 2011 | 08:18 PM
motorcarman's Avatar
Yes the Primaries can cause an engine rattle. They don't fail as often as the secondaries, but I have replaced failed/damaged lowers and the curved tensioner blades that rattled as a result.
TSB for you
The warranty times are NOT real world, but that was all Jaguar was willing to pay for the engineering mistake.
bob gauff
Old Feb 21, 2011 | 10:22 PM
Skid Mark's Avatar
Thanks guys. I talked to my indy tech today and he said because the noise goes away after engine warm up, it could be a partially blocked oil port for the tensioner(s). He reccomended a lighter weight oil to see if it went away. I'll take it in tomorrow so they can take a listen w/the stethoscope.
SD96XJ6L
Jan 12, 2022 04:30 AM
Sprayall
May 30, 2021 08:13 AM
PMKimpton
Aug 3, 2019 08:22 PM
Sprayall
Sep 3, 2015 07:49 PM
innzane
Sep 2, 2015 10:08 AM
