Lug nuts
Old Nov 4, 2019 | 07:00 PM
66RBS's Avatar
Default Lug nuts
Went to purchase 21 mm socket for lug nuts and discovered they are actually 22 mm
they have a decorative cap on them. The caps are slightly loose but the lug nuts aren’t. Are these Jaguar OEM or aftermarket
Old Nov 4, 2019 | 07:08 PM
RJ237's Avatar
Probably OEM. That's what mine have always been, and he same for several cars I worked on.
Old Nov 4, 2019 | 08:16 PM
DavidYau's Avatar
+1 to RJ237.
I have the same lug nuts here. So I would think they are OEM lug nuts. I'm thinking of replacing these as the loose cap, I suspect, will eventually work loose from the threads. Fellow Forum member Rothwell has looked at many different solid lug nuts for his newly refurbished rims. If you're going down this route, I would check his threads on this forum. He's done some lovely under-stated upgrades to his car to make it more user friendly.
Old Nov 4, 2019 | 09:23 PM
rothwell's Avatar
Yeah those are the horrible OEM lugs. I have always replaced them with solid ones ever since I had one of the outer covers start spinning on the lug inside. Happened on my first Jaguar S-Type about 15 years ago. Plus the outer caps being loose fitting would create a chatter that I could hear at low speeds, particularly in parking garages.
Here's the thread with the lug nut info.
To get this look is about $40 total for lugs and center caps.
J5hort
Nov 12, 2021 08:25 AM
staggerwing17
31
Nov 8, 2021 08:06 AM
giandanielxk8
Apr 3, 2018 10:27 AM
Jon89
Jun 29, 2013 02:16 PM
Noxparadise
Dec 1, 2012 10:16 PM
