luggage compartment lights
Old Mar 4, 2018 | 10:12 PM
TexGator's Avatar
Default luggage compartment lights
The Luggage Compartment lights on my 1999 XK8 Convertible are not working. I have tested the bulbs and they are fine, but I can't find the fuse for that line. Does anyone know which Fuse Box and fuse it is?
Old Mar 5, 2018 | 02:46 AM
I've deleted your identical post in X150 forum.
Controlled through the BPM (Body Processor Module) and not fused separately. see the section I've boxed in red:
As the bulbs are OK, suspect the switch or a harness break where it attached to the luggage compartment lid. With the flexing from repeated opening and closing, this is a regular place for a cable break.
Old Mar 6, 2018 | 07:27 AM
TexGator's Avatar
thanks, I will check into that
Old Mar 6, 2018 | 11:10 AM
Fairfalcon's Avatar
Tex,
I had the same problem on my '97 conv. and fixing the #7 fuse in drivers door fuse box solved the problem.
Mike in TN
n17gary
Dec 6, 2023 05:26 PM
Long Islander
Nov 26, 2017 06:40 PM
Long Islander
Sep 8, 2012 06:30 PM
ashlander
Jul 23, 2010 05:50 AM
