Manual trans
Old Jul 10, 2020 | 02:03 PM
Loxmth's Avatar
Default Manual trans
Did a small search didn’t find much. I have a 2003 XK8. Trans is acting up and i might need to replace it. I figured I’d look into the possibility of installing a manual, which should have been and option. I don’t care about traction control or anti lock brakes. It’s not a daily driver. Inspection in that regard not an issue.
I’d also like to change the rear gears.
Old Jul 10, 2020 | 02:47 PM
avern1's Avatar
It has been done. Take a look at the link below for a thread about it. Be sure to take note at post #6. Paragon group knows of what they speak.
https://www.jaguarforums.com/forum/x...n-done-108694/
Old Jul 10, 2020 | 10:58 PM
DavidYau's Avatar
Loxmth,
It's a serious project to switch the AJV8 & auto. gearbox to a manual set up. Big fat wallet needed, spare down time, and some serious mechanical and electrical skills needed. Note that the CAN-BUS computer network will need serious re-work for the modules to retain functions.
If you want to go down this route, USD12k seems to be quoted as a starting budget, and I would imagine that it'll be easier to do a complete engine and gearbox replacement, with new ECU. On this forum, Jaguar Specialities put in a LS engine with a manual gearbox. Check out this thread on the subject esp. post no.8
https://www.jaguarforums.com/forum/x...nto-xk8-61020/
Just my 2 cents. Food for thought. Just don't tell the wife what you're thinking.
Quickstep192
Feb 4, 2024 05:30 AM
Jakepatch
Feb 4, 2017 08:01 AM
smith356
Oct 18, 2016 11:35 AM
JaguarJoseph
Jul 27, 2014 07:03 PM
