Map Lights 1997 XK8
Old Aug 22, 2022 | 01:56 PM
Jaguar2373's Avatar
Default Map Lights 1997 XK8
Hi Guys ! ... For some reason the Map Lights (on top of the rear view mirror), they go off when you open the doors, but once inside you want to light them up and they won't work.
Any tricks or settings that I am missing or don't know off ?
Thank you all !!!
Old Aug 22, 2022 | 07:35 PM
Johnken's Avatar
J., sometimes "go off" means ignite (turn on), other times it means turns off.
Sorry but don't want to assume. Please clarify.
BTW, while you're typing please say door position for the when inside part mate. (Door open or closed?)
John
Old Aug 23, 2022 | 09:14 AM
Jaguar2373's Avatar
Thanks !
While doors are open ... map lights work. But once you are inside the vehicle and you need to turn on the map lights, they don't light.
Old Aug 24, 2022 | 12:49 AM
Pistnbroke's Avatar
See handbook . Mine stay on about 20 seconds after I close the door.
Old Aug 24, 2022 | 08:24 AM
Johnken's Avatar
Ok got it. Mine are individually switched, push to light. What to push? I never use them, I forget if its a switch or the bulb assembly. Based on the bulb assembly yelling at me last week as I pressed the pod in place, there's a off/on switch up there. Look around?
Btw they are not designed to illuminate if you turn the dimmer switch to click position.
John
Old Aug 24, 2022 | 06:26 PM
Johnken's Avatar
Just looked. Press black button behind light.
John
Old Aug 26, 2022 | 11:08 PM
DavidYau's Avatar
Default Picture speaks a thousand words
Here’s a few pics
datriani
Jan 19, 2022 08:05 AM
cujet
Jun 12, 2017 02:22 PM
booklaw1
XE ( X760 )
Jan 15, 2017 05:51 PM
Telecom
Dec 27, 2015 06:57 AM
smachell
Jun 19, 2014 08:59 AM
