Map lights replacement
Old Dec 7, 2019 | 04:30 PM
ieccpa's Avatar
Default Map lights replacement
Need to replace map lights on my XK8 2005, an afraid to break it. Can someone explain me how to do it. Thanks
Old Dec 7, 2019 | 09:02 PM
DavidYau's Avatar
Ieccpa,
Map Light?? Are you referring to the overhead console reading lights?
Do you have the Coupe or the convertible?
Replacing these overhead light bulbs is relatively straight forward as the console is held up by 3 push fit clips that pry off. Then it’s easy to see the fuse type light bulbs that may need replacing. I attach a couple of pictures of the unit.
Exterior view of the unit
interior view of the unit
Old Dec 7, 2019 | 09:50 PM
giandanielxk8's Avatar
Pull gently, and straight down. The plastic bracket to which the clips are held on to is very brittle. There's three clips, and the clips themselves are made out of some metal.
srpope80
Jun 16, 2017 02:15 PM
GrtShrk
Nov 22, 2014 03:26 PM
nyfilm
May 9, 2014 01:45 PM
Spurlee
Oct 14, 2011 12:10 PM
Toller
Jan 6, 2009 11:42 AM
