MAP sensor vac line origination on XKR?
Old Mar 10, 2025 | 09:12 PM
2500DollarXKR's Avatar
Default MAP sensor vac line origination on XKR?
Firstly, a big thank you for all you folks willing to help me bring this XKR back from Plonkerville. I'm down to one code via OBDII! MAP sensor. Well then. Let's inspect! Wiring seems to be good! Let's check the vac line to the map sensor, and....
(no vac line to MAP sensor)
So now, I need to determine where that vac line is supposed to either connect or tee in, and if it really matters WHERE, or if just a general access to the vac subsystem will suffice. Any pointers? I've not found a good diagram or link that's 404 yet. If someone could just take a quick pic under their XKR hood when they get the chance... the MAP sensor is directly behind the throttle body on the firewall, connected via a bracket. Usually Denso P/N LNF1622AA.
Old Mar 10, 2025 | 10:55 PM
Welp. I found the line, capped off and tucked under a bunch of stuff. Reconnected, reset OBDII and no more P0105. Why on earth would anyone take the time to cap off the MAP? It's a cap in and of itself! So many stupid plonker things done to this car. Ooof. Down to just the P1000 drive cycle code now. Maybe, just maybe, I'll pass emissions!
Old Mar 19, 2025 | 10:35 PM
fourkegdave's Avatar
Nice, now you just need to drive it and enjoy
sam1977
Feb 27, 2024 08:39 AM
johnleavitt
Jul 28, 2023 02:08 PM
ferrral
Aug 13, 2021 04:11 PM
98 shadow
May 21, 2020 09:39 AM
swdodson
Sep 11, 2018 12:22 PM
