Mass airflow sensor
Am planning on replacing my maf sensor on my 2004 XKR and was wondering if the xk8 uses an identical part. I can get an xk8 sensor more cheaply than an XKR one.
Why are you replacing the old one? Is the car playing up To find if the old unit is faulty just unplug it. The car won't like it at first and tickover will be messy for a minute or so, and you'll get 'restricted performance' - but the ECU will revert to default settings. If the performance improves then the MAF is faulty.
I have cleaned it twice and although it is running noticeably better it's still a bit jerky at low RPM's, so I figure it's on it's way out.
I tried unplugging it but the engine ran much worse, although I must admit I didn't probably leave it long enough for it to revert to the default settings.
I know the Mazda 6 can be swapped for the XK8 maf but was wondering about the XKR. Different part numbers but the internals might be the same.
I took the MAF out of my XJ8 and put it in my XK8 and it was fine. Numbers were very different too.
Do yourself a favor, and buy the correct MAF for your car, and buy an OEM or OEM quality part. Dont cheap out on this one, or you will likley get lean codes, restricted performance, etc. You can buy a Denso unit from WorldPac, etc.
I've been running the Mazda 3's MAF sensor for about 5 months now and I haven't had a problem. It is exactly the same part except for the part number. You can safely cheap out on this. The Jaguar part is overpriced and sourcing it from Denso is becoming troublesome.
FS[SouthEast]: XK8 Parts for Sale
glenng
Nov 21, 2015 05:56 PM
