Mike Whisky 4500 XK8 2001 Hello and a tale of ineptitude
Old Jul 25, 2016 | 01:43 PM
Mike Whisky 4500's Avatar
Default Mike Whisky 4500 XK8 2001 Hello and a tale of ineptitude
Hi There All,
I am new to this although I have often sat and searched through your collective wisdom to help with various snags that my 2001 XK8 has thrown at me.
Firstly many thanks for your help on these occasions, although you could not have known many of you have allowed me to not stress about the odd light or rattle here and there.
My tale of ineptitude is that having changed the upstream O2 sensor on bank 1 (Thanks to you guys) I took the beast for a quick run to warm her up and make sure that I had indeed hit the correct sensor. My ineptitude came in the form of leaving my code reader ( A cheap one) dangling in the drivers pocket attached to the connector. What could possibly go wrong! Everything is the answer to that little question, I saw lights that I did not know I had lights for!!
Any way after a quick Off and On again I had the engine check light to keep me company on the way home, after coupling the reader again I found that it was CAN bus code that had been set by the reader.
Anyway thanks guys and Girls for all the help and I am happy to be among your numbers
Regards
Old Jul 25, 2016 | 01:53 PM
03 XKR's Avatar
Is the Check Engine Light still on? You should perform a 'Hard-Reset' to clear out any erroneous anomalies floating around the system that may have been generated from the code reader. Also, did you perform a 'Hard-Reset' after changing the O2 Sensor? I believe the procedure is mandatory after replacing certain components; a light bulb--no, an O2 Sensor or other electronic component--yes.
Old Jul 25, 2016 | 02:00 PM
Thanks for the advice, I cleared all fault codes using the reader, everything else seems to be working. I do have a battery dis-connector fitted, so if any spurious light come on I will loose the power for a few seconds and earth down the terminal.
Regards
Lothar52
Jun 3, 2016 10:55 PM
adenshillito
May 23, 2016 02:54 AM
roger.neill
May 18, 2016 04:56 AM
adenshillito
May 13, 2016 11:29 AM
espy1949
Apr 29, 2016 07:25 AM
