Milky Foglights
Old Jan 13, 2025 | 07:45 AM
PacificBlue's Avatar
Default Milky Foglights
X100 XKR with flush fog lights that have gone opaque. I am told I have to buy new. Surely not. Does anybody know how to refurbish them?
Old Jan 13, 2025 | 09:48 AM
giandanielxk8's Avatar
They're just dirty from the inside. You can access through the wheel well and clean them up with a microfiber towel. You do have to remove the wheel well liner to have enough room. You also have to flip over the bulb housing. It is quite easy and it will make sense once you're in there.
Old Jan 13, 2025 | 02:04 PM
wymjym's Avatar
or if you remove them you can separate the rear assembly from the housing/lens. and clean away.
wj
Old Jan 14, 2025 | 02:30 AM
wj
Thank you so much Guys, that will certainly save a few Pounds!
Old Jan 14, 2025 | 02:38 AM
Very grateful for the information, many thanks!
Old Jan 15, 2025 | 01:05 PM
zray's Avatar
Take care with the metal clip that holds in the lens. After 20 years the lens is more brittle and prone to cracking.!
Z
Old Jan 16, 2025 | 02:15 AM
Thanks for the tip I will treat with kid gloves!
95 Cat
Dec 14, 2024 05:41 AM
rgp
Feb 27, 2023 09:47 PM
Wv xjs
Aug 6, 2015 01:05 AM
Jeff in Tucson
Sep 15, 2012 07:50 AM
