2000 xk8 trunk (boot) will not open
Old Jan 15, 2025 | 11:21 AM
joekluger's Avatar
Unhappy 2000 xk8 trunk (boot) will not open
Just got this 2000 xk8. Problem is a dead battery. I added power through the hood at the fuse box terminal. Trunk is stuck shut. Key will not open and looks like it's stuck in Valet mode. Tried to unlock the door with the black key but no luck. I do not have a remote for this car. After reading all I can I have been not able to come up with any solution. If anybody can help would be greatly appreciated.
Old Jan 15, 2025 | 11:45 AM
RichardS's Avatar
It sounds as if you can open and close the doors with the black key? If you fully charge the battery through the fuse box terminals, can you start the engine with the black key? Do not try and jump start the car using those terminals.
Once the battery is fully charged enough to start the engine, or just reasonably well charged, can you open the trunk with the dashboard switch? If you can, you can then lubricate the lock mechanism from inside (I assume that you tried spraying some oil into the keyhole from the outside?) and get the black key working in the trunk keyhole.
Richard
Old Jan 15, 2025 | 01:11 PM
joekluger's Avatar
I locked and unlocked the door with the black key and then started the engine with a small boost with another battery.. still will not come out of valet mode and will not open the trunk.
Old Jan 15, 2025 | 06:10 PM
MVMonarch's Avatar
It’s not hard to miss the boot switch and press the valet switch by mistake. As I recall, valet mode is reset by locking and unlocking the doors with the fob. Since yours is MIA, you may be stuck.
Old Jan 15, 2025 | 07:04 PM
motorcarman's Avatar
The only way to disable VALET MODE is to have the SCP network modules recognize 'BOOT LID OPEN' !!!!!!!!!!!!!!!!!!!!!
If the lid is opened and the latch switch is INOP or disabled, the car will remain in VALET MODE.
The INSTPK needs to display that it is open or the boot lamps need to illuminate.
NO OTHER WAY.(maybe replace the relevant modules?)
No one uses the boot lid key so it usually is seized with corrosion or debris buildup.
Use the key a few times a year to prevent this failure.
I had to work for almost half an hour the free up a boot lid lock with PB Blaster/Kroil/Liquid Wrench a little at a time.
I could feel it move little-by-little and finally free.
Pretty much no sympathy for people that neglect the locks and then wonder why they won't work.(duh)
Old Jan 15, 2025 | 07:30 PM
joekluger's Avatar
Am I understanding this correctly? It will not come out of valet mode if the trunk is not open and the trunk will not open in valet mode. Is there something wrong with this logic? So how to resolve this?
Old Jan 15, 2025 | 07:50 PM
MVMonarch's Avatar
Try this thread:
https://www.jaguarforums.com/forum/x...esolved-48048/
Old Jan 16, 2025 | 01:43 AM
dibbit's Avatar
Almost correct. Valet mode is to prevent valets from getting in to the boot (using the valet key or the button on the dash), therefore it can only be cancelled by the owner with the black key (which will open the boot) or the remote key fob. You don't have a remote fob and your boot lock doesn't work - that isn't a fault with the logic.
Read Motorcarman's post above.for how to resolve this.
Old Jan 16, 2025 | 03:34 AM
RichardS's Avatar
Have you tried spraying plenty of oil into the keyhole in the XK8 badge at the rear and gradually working the black key left and right as I suggested in post #2?
What happens when you try this? Can you feel any movement?
Richard
Old Jan 16, 2025 | 03:38 AM
bladerunner919's Avatar
When you do get the boot open, I strongly suggest dropping the trim panel under the steering wheel and disconnecting the valet button.
playmesa
Jan 7, 2020 01:15 AM
middlemarsh
Jan 22, 2017 04:26 AM
dad2twins
Apr 30, 2012 12:50 PM
grrrrwl
Sep 6, 2009 12:06 PM
TonyW
Jul 6, 2009 06:15 PM
