Mitzone Aluminum 4.2L Coolant Tower install
Old Mar 6, 2026 | 03:37 PM
kstevusa's Avatar
Default Mitzone Aluminum 4.2L Coolant Tower install
Just completed the install of the Aluminum Coolant Tower , on my 4.2L The unit was great looking and seems to be the option we've been needing. The Rear section mounted ok to the block with the usual attempts on the 2 rear next to plenum. The front piece that mounts to the block with 4 bolts had to be modified . The 4 holes were not adequately spaced to allow the bolts to align w/o threat of cross thread. I used a 13/64" drill to enlarge all 4 holes and my bolts went in block smoothly. I removed the new Temp sensor and replaced the new thermostat since the existing ones worked great .
Some pics. maybe later
Old Mar 7, 2026 | 08:04 AM
Jon89's Avatar
Sorry to hear about the fitment issues, Kelly. Sure hope the mounting holes enlargement indeed fixed it. Keep us posted....
Old Mar 7, 2026 | 11:32 AM
kstevusa's Avatar
Yes, the part appears leak free and bolted up OK. The 13/64 drill allowed adequate clearance for the 4 Bolts ( 6.25x25mm) to align and thread in without problems. The square rear portion also uses the same bolts. Mitzone has a contact message link so I advised them of the situation and suggested they enlarge the 4 holes to 5.2mm to avid mounting problems. Cross threaded bolts are not my thing :-)
File Type:
File Type: html
Old Mar 7, 2026 | 11:41 AM
cjd777's Avatar
Thanks again for a great fix Kelly.
I bet lots of business will be headed their way.
Old Mar 10, 2026 | 12:11 PM
H20boy's Avatar
Is it this one?
MITZONE Aluminum Engine Coolant Thermostat Housing Water Outlet Assembly Compatible with 2004-2005 Jaguar Vanden Plas XJR XJ8 2003-2005 Jaguar S-Type 2005 Super 4.2L V8 AJ89485
https://a.co/d/0hgzPR4J
Old Mar 10, 2026 | 12:45 PM
kstevusa's Avatar
Mine came from E Bay vendor Autowild Auto, your link led me to a unknown shopping page. I did swap the temp sensor and Stat. the Stat appeared less quality.
chillyp
Nov 30, 2022 04:46 PM
lalanurm
Sep 4, 2018 02:09 PM
2000CAXK8
Feb 25, 2012 05:11 PM
gchin
Feb 20, 2011 09:03 PM
Gus
May 29, 2009 09:28 PM
